Will Susp off 96-2000 civic work for 94 civic?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlc92189 »</TD></TR><TR><TD CLASS="quote">hey guys there kyb agx shock with h&r spring coming off 96-00 civic. will this work with 94? any mods needed?</TD></TR></TABLE>
the spring should bolt right up but the shocks will not bolt up. You'll need to trim down the lca bushings. I've heard you can swap out the 96-00 civic LCA's for 94-01 integra LCA's. Somebody correct me if i'm wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua »</TD></TR><TR><TD CLASS="quote">I've heard you can swap out the 96-00 civic LCA's for 94-01 integra LCA's. Somebody correct me if i'm wrong. </TD></TR></TABLE>
Shaving the bushings is the only way. Integra LCAs will not fit 96-00 Civics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">
Shaving the bushings is the only way. Integra LCAs will not fit 96-00 Civics.</TD></TR></TABLE>
thx for the correction blueintegra
eknorcal
Oct 2, 2006 09:25 PM
