Need help. Don't know what parts i need
i read a lot of related stories on ht about flying over a crub and some are very close to what happen. I did bent a frame, my driver side wheel is pushed back, i know something in the suspension side needs replacing but i don't know what it is. Here are some picture so you guys have a clue.
if you need more picture, i don't mind taken them but tell me what specific part
Let's see a picture of the overall placement of the wheel. Step back a few feet and snap a picture of the wheel (car on the ground) so we can see how the wheel is moved.
Inspect your lower control arm -maybe provide a picture there.
How about your radiuas rod -inspect or proivde a picture.
Maybe a few better pictures of the damage done to the cross member. From that angle, you can only tell it got damage, hard to see if it was pushed in the center or not.
Another suggestion - depends on how welling local shops are willing to provide information. Many times, if you go and try to get an alignment, the guys there will tell you what they see needs replacing and why that can't align it -then replace and go back and get that alignment at the same place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirrvanna »</TD></TR><TR><TD CLASS="quote">
You can see where this came back and hit the car....now it looks a little out of place, sorta bent. Hard to tell from a picture or the angle -but something to look further into.
Shiznit028
21
Dec 17, 2008 03:39 AM
