real lca issue!!!!!!!!!!!!!!!
Old Jul 28, 2007 | 02:24 PM
autoxthis's Avatar
Default real lca issue!!!!!!!!!!!!!!!
Just got my ground controls mounted on tokiko blues and when i went to install the rears I noticed the LCA would not work with the new shock mount fork.
My LCA's have a hole where the shock drops down into and a bolt runs through the lca and into the stock shock (its like threading a needle).
New shocks have fork style mount with no bushings and they are supposed to mount around the LCA. I just bought the car and now suspect the rear suspension is swapped from different year. If it helps the car is a 91' CRX HF.
MY main question is does anyone have any idea if the LCA's are stock or replaced?
Old Jul 28, 2007 | 02:27 PM
snowseeker's Avatar
Default Re: real lca issue!!!!!!!!!!!!!!! (autoxthis)
you got the 90-91? lower control arms where like you said the shock bolts up inside the lca. You wanted to get the 88-89? lca.
I am not very sure on the years hence the ? after the years.
Old Jul 28, 2007 | 02:38 PM
99teggsr's Avatar
Default Re: real lca issue!!!!!!!!!!!!!!! (snowseeker)
if you have fork style shocks you need 89-91 LCA's, if your shocks are the drop in style you need ITR or 88 LCA's.
silver_racer
Feb 18, 2009 09:40 PM
stevescivic
Oct 3, 2007 04:21 PM
autoxthis
Aug 23, 2007 11:57 AM
Benard
Jul 8, 2006 10:14 PM
uneekcrx
Jun 17, 2002 06:50 PM
