Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
head light-bulb
Old Jul 28, 2007 | 12:26 PM
rtt1737's Avatar
Default head light-bulb
06 civic ex navi coupe
i would like to change the light bulb into some colored or clear light. i cant get to the bulb because there is no space for my hand to get in there.
please help
Old Jul 28, 2007 | 02:09 PM
originalg00kster's Avatar
Default Re: head light-bulb (rtt1737)
you can either go thru the wheel well on the passenger side....or just straight down from popping the hood...and the drivers side...you hvae to remove the coolant box thing and maybe the battery tie down bar.
Old Jul 28, 2007 | 06:12 PM
accordselux's Avatar
Me Gusta History
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtt1737 &raquo;</TD></TR><TR><TD CLASS="quote">06 civic ex navi coupe
please help
What kind of bulb are you looking for?
When you start using colored bulbs, you start losing light output because it is filtering out useful light.
Old Jul 29, 2007 | 02:03 PM
rtt1737's Avatar
i'm thinking about the Piaa extreme white #9006 for about 80 dollars. what do u think
Old Jul 29, 2007 | 02:10 PM
Nighthawk R18's Avatar
Default Re: (rtt1737)
whats the level of K?
im at 7500k and i cant see ****.
Old Jul 30, 2007 | 09:58 AM
Striker_1818's Avatar
PIIA's have coating on them.
Coating will act like a shield. less light will go through the glass bulb hence the coating is shielding light from escaping for color purposes thus u get less lumens.
PIIA = crap
TRUE Silverstars = non-coated bulbs with whitish output
OEM = good bulbs
Old Jul 30, 2007 | 01:48 PM
Me Gusta History
That's not worth the money at all. PIAA is so very overpriced for what it does. If you want more light, look for a nighthawk or a 9012 HiR bulb. The HiR bulb is a special type of infra-red reflecting bulb, they cost half as much as PIAAs and will probably offer more light without changing the wattage. You can get nighthawks at WalMart even, they're cheap. They'll both put out more (i didn't say better!) light.
If you want color, just go for an HID retrofit. You can get some HID color in a kit, but it will be kind of obnoxious.
Most coated bulbs are detrimental to your lighting.
Danielsternlighting.com has some good automotive lighting FAQ's that will explain why colored bulbs are garbage for the most part.
DarkCyde SI
Aug 18, 2006 01:31 PM
greenV6EX
Jan 26, 2004 10:23 PM
niteboyzzz
May 12, 2003 01:49 PM
