Clunking sound- From Right Rear- Just put on springs.....?
Old Jul 28, 2007 | 09:39 AM
aln2590's Avatar
Default Clunking sound- From Right Rear- Just put on springs.....?
Hey i recently got H&R lowering springs installed on my 96 accord lx. Ever since, i have been hearing a somewhat loud clunking sound every time i hit a bump or rough spot in the rond that causes my car to jump or bounce a little. I here a clunk clunk, coming from the right rear- any ideas? I checked the springs, and even bounced the right rear of my car to compress the springs but heard nothing.
Any help would be great!
Old Jul 28, 2007 | 11:17 AM
Bruce Banner's Avatar
Default Re: Clunking sound- From Right Rear- Just put on springs.....? (aln2590)
did u put it in yourself?
Old Jul 28, 2007 | 11:22 AM
R1Moon's Avatar
Default Re: Clunking sound- From Right Rear- Just put on springs.....? (Bruce Banner)
It sounds like the spring isn't seated properly, jack up the car and see if the ends of the spring is sitting in the groves on the upper and lower of the strut. If it isn't you should be able to twist the spring around until it sits in the groves.
Old Jul 28, 2007 | 12:11 PM
aln2590's Avatar
Default Re: Clunking sound- From Right Rear- Just put on springs.....? (R1Moon)
thanks- i'll try it
Old Jul 30, 2007 | 11:42 AM
slomob18b's Avatar
If the springs are seated properly, the coils might be hitting each other when they are compressed. What kind of shocks are you using and are they new?
Old Jul 30, 2007 | 11:56 AM
aln2590's Avatar
Default Re: Clunking sound- From Right Rear- Just put on springs.....? (slomob18b)
THE SHOCKS ARE STOCK, THE SPRINGS ARE H&R....THE 1.5/1.75IN DROP...
Old Jul 30, 2007 | 12:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aln2590 &raquo;</TD></TR><TR><TD CLASS="quote">THE SHOCKS ARE STOCK, THE SPRINGS ARE H&R....THE 1.5/1.75IN DROP...</TD></TR></TABLE>
I THINK YOU MEAN 1.75F, 1.5R
Old Jul 30, 2007 | 12:03 PM
slomob18b's Avatar
For that kind of drop I would have replaced the shocks at the same time when you replaced the springs. Sooner or later the oem shocks will blow if they haven't blown already.
Old Jul 30, 2007 | 12:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomob18b &raquo;</TD></TR><TR><TD CLASS="quote">For that kind of drop I would have replaced the shocks at the same time when you replaced the springs. Sooner or later the oem shocks will blow if they haven't blown already.</TD></TR></TABLE>
yup
Old Jul 30, 2007 | 02:51 PM
aln2590's Avatar
What shocks do you suggest? Taking price into consideration...
Old Jul 30, 2007 | 02:55 PM
koni Yellow
Old Jul 30, 2007 | 03:01 PM
aln2590's Avatar
I'm sure there top of the line but DAMN there expensive
Old Jul 30, 2007 | 03:10 PM
you can go one step down and go illumina
Old Jul 30, 2007 | 03:11 PM
aln2590's Avatar
How about the Tokico Hp Blue shocks- I can get a full set for just under 250
Old Jul 30, 2007 | 03:17 PM
They will work.
Personally I would not since the front is dropped 1.75.
I have KYB AGX on my H&R.
Not recommended, but so far so good.
rekreb38
Suspension & Brakes
Nov 3, 2010 10:30 AM
docbrown
Suspension & Brakes
Jun 19, 2009 07:22 PM
BlueRex1020
Feb 9, 2007 04:43 PM
nicksweetlude
Aug 6, 2002 07:07 AM
bolognatits
Aug 29, 2001 11:33 AM
