Prelude dies at idle.. Idk wat to do HELP PLEASE
Old Jul 27, 2007 | 09:07 PM
IA95civicDX's Avatar
Default Prelude dies at idle.. Idk wat to do HELP PLEASE
ok its h22a1, in a 96 prelude. Car has 0bd2 to obd1 harness with a chipped p.28. It seems to run ok if you give it some gas but not just rite. It started doing this after i got on the car a little.. I pushed the clutch in and the car died. If you try and start it back up it will just run for maybe one sec unless you give it some gas then it will stay running. IDk bad ecu? head gasket? it looks like it is leaking just a bit of coolant from around the water pump area, but it dosnt over heat. No knocking noises, occasionaly misses now though,
Old Jul 27, 2007 | 09:26 PM
lude98SH's Avatar
Default Re: Prelude dies at idle.. Idk wat to do HELP PLEASE (IA95civicDX)
could u try running it on a known good ecu ?
Old Jul 28, 2007 | 08:13 AM
Default Re: Prelude dies at idle.. Idk wat to do HELP PLEASE (lude98SH)
No, i just bought the car as a daily driver and only have some stock sohc ecu's
Old Jul 28, 2007 | 08:41 AM
310sieg's Avatar
I think its your IACV. I had the same problem before.
Old Jul 28, 2007 | 09:26 AM
Default Re: (310sieg)
is it normal that it would just die when you blow the iacv out though? cause on my D series they just cant hold a steady idle
Old Jul 28, 2007 | 01:30 PM
310sieg's Avatar
its probably just dirty.it dies if yu dont press on the gass a lil bit but once your car is warmed up it idles perfect.it should throw a code because mine did
simon.vada
Sep 23, 2018 04:50 PM
IHEARTMYHONDA91
Dec 18, 2010 01:38 PM
Zman1764
Aug 7, 2007 08:41 PM
BB6Paul
Oct 5, 2006 10:43 PM
Skyllz
Sep 18, 2003 04:59 PM
