ECU Problem!!
Old Jul 27, 2007 | 05:46 PM
zcsport's Avatar
Default ECU Problem!!
i finally fix my check engine light with code 8 but now something is up,my check engine light is off but the ecu is flashing code 15,it's there anything wrong or it's normal,because it doesn't flash when i reset the ecu but after a week or so it start to flash again!! thanks for help!!1989 civic si
Modified by zcsport at 7:29 PM 7/27/2007
Old Jul 27, 2007 | 06:01 PM
zcsport's Avatar
Default Re: ECU Problem!! (zcsport)
oh yea i checked everything and i found out ecu pin b15 has low voltage --about 6 volt,and b17 has 12 volt,basically i just don't know what's really going on if wiring have problem,my car wont start,right???
Old Jul 27, 2007 | 06:26 PM
ef-hatchcrap's Avatar
Its a intermintant problem try swaping the dizzy with a known good one or change the sensor.
Old Jul 27, 2007 | 09:01 PM
zcsport's Avatar
Default Re: ECU Problem!! (ef-hatchcrap)
ok,thanks for your reply, i replaced the ignitor on the dizzy that i'm using like three weeks ago!!so i don't know i may put the other dizzy on but i don't know how do i find out what the problem is because it doesn't flash right the way!!and even if it flashs,i dont have check engine light on!!
mikej94civex
15
Jan 6, 2010 02:46 PM
bub113
Dec 19, 2008 09:27 AM
nexus da9
Apr 7, 2004 07:37 PM
BigMig
May 10, 2003 06:01 PM
seemo
Oct 12, 2001 11:21 AM
