i have my list for the gsr to crx.
this is my list for a gsr into a crx dx please let me know if this is the way to do this.
gsr motor
b16a tranny
b16 shift linkage
90-93 integ axles
hasport mounts
b16 rechipped to itr spec ecu
b16 distibutor
b16 alternator
b16 injectors
thank you all.
gsr motor
b16a tranny
b16 shift linkage
90-93 integ axles
hasport mounts
b16 distibutor
b16 alternator
b16 injectors
thank you all.
is this a general list or do you want specifics
what about cables: ls throttle, clutch, and speedo
brackets: ls driver side mount, rear mount (i am talking about the parts that bolt to the motor, not the aftermarket stuff)
what intermediate shaft u using
at least these are the parts i was told i needed so i bought
you have been on here awhile so i know youve seen this site, but...
http://www.hasport.com/M88_B16_partslist.htm
yeh, i checked out the site but it seems like i have to get hasport this and that. im just trying to make this the easiest low cost swap as possible.
eventually you will want to get some gsr injectors.
axles will depend on what intermediate shaft you run.since youre putting in a gsr motor , use the intermediate shaft from like a 94 gsr (the one that is male on both ends) along with gsr axles for the same year (both passenger and drivers side). This is what fits best in my crx and as long as you use the HCP engineering orHASPORT mounts this is the ideal setup.
I am thinking of the same swap in my 90 HF. So if I purchase a 94 B18c swap I can use the axles and shafts that come with the motor? Cool I never knew that.
where did u get your hcp mounts? how are they holding up?
no modifications were necessary to the axles or intermediate shaft and even with my car lowered 2 inches i have yet to tear a boot or break an axle even with full 6 puck , 6500 rpm drag launches WITH 10 psi of BOOST! for info on the mounts go to hcpengineering.com. theyre the best in my opinion,they use all four mount points for more stability, they look good (black with red urethane),and they are beefier than hasport(i have 2 friends who have broken tranny mounts from hasport and they arent even boosting)....,also if i remember correct they are about $325-350 for the whole kit.
On the injectors, you can use the GSR injectors if you just eliminate the injector resistor box. You can put the gang plug form the GSR harness on that part of just solder all the wires together at the injector resistor box plug.
brian g
brian g
Boosted Stu
Texas -OK -LA (Sales)
Aug 30, 2012 09:43 AM
RaysBoomBoomLude
19
Nov 1, 2006 06:18 AM
