car wont start (searched)
Old Jul 27, 2007 | 01:09 PM
Fezzie's Avatar
Default car wont start (searched)
ok i have a jdm b16 with ctr cams in my Ef sedan now the b16 came out of a perfecctly running crx then i front end got messed up in the rex and i swaped the motor to the sedan and it will not start. the only code i threw was ICM so i went and bought a brand new ignitor, coil, plugs, wires, and the tps got broken so i bought a new one and still no go, but the thing is it takes lik a good 15 min of crankin with start fluid to start it and i have to play with the throttle alot. but now it just cranks and thats it.
heres a list of everything i checked and most tested good.
main relay- good
injectors- good
spark- no spark since i changed the ignitor but everything is on correct.
compression- 180-175-175-180
grounds- good
ecu- good, same ecu that came witht the motor
wire harness- completly stock never cut
tps voltage- .45
map voltage- good
timing- good
spark plugs- they are black
fuel pump- good
Old Jul 27, 2007 | 02:14 PM
mahatma's Avatar
Default Re: car wont start (Fezzie)
and you're sure that the mpfi wiring on the sedan was done correctly?
Old Jul 27, 2007 | 06:01 PM
Fezzie's Avatar
Default Re: car wont start (mahatma)
yup its a ex
Old Jul 27, 2007 | 11:34 PM
Fezzie's Avatar
so theres not one person that has had this problem.
Old Jul 28, 2007 | 06:14 AM
Fezzie's Avatar
help
snake208
Jan 3, 2011 07:12 AM
Fezzie
Aug 2, 2007 11:08 AM
aaronhume
Apr 6, 2005 11:28 PM
RussHondaCRXVtec
Dec 17, 2003 10:40 PM
RussHondaCRXVtec
Dec 16, 2003 09:37 PM
