For Those with JDM fronts... Front filler question.
Old Jul 27, 2007 | 11:59 AM
DIYMIKE's Avatar
Default For Those with JDM fronts... Front filler question.
here is a picture of my hatch..... i am currently out of state and i am not around my car but this was one of the problems i remember and bothered me....
when i come back i am going to fix it.
any way. when i put my jdm front on.... i notice that the front filler did not bolt up in these two areas circled in red.... there was a gap of around 1 inch to bolt it in, which i would have to push the fuller towards the firewall to fit but that would bend the filler peice.... the center bolt which bolts to the Tbar was bolt on..... but the sides do not.....
did anybody have a problem like that???
also one thing to consider is that i purchased this jdm front brand new... so there might be parts i could have been missing but i could be wrong.
Old Jul 27, 2007 | 12:03 PM
ef9robert's Avatar
strange, you sure you didnt' miss the holes on the side since the jdm clip i have installed has the 2 bolts one on each side that connect the filler piece to the t-bar.
Old Jul 27, 2007 | 12:04 PM
ef9robert's Avatar
take that back, not on the t-bar, i will have to check when i get home.
Old Jul 27, 2007 | 03:10 PM
DIYMIKE's Avatar
Default Re: (ef9robert)
thanks for looking out.
Old Jul 28, 2007 | 09:09 AM
DIYMIKE's Avatar
Default Re: (DIYMIKE)
bump
Old Jul 28, 2007 | 10:26 AM
Chewy Built !'s Avatar
just curious, does your bumper hit the filler piece, on those points you have mentioned? Reason i ask, is because i just noticed mine does.
Old Jul 28, 2007 | 11:03 AM
DIYMIKE's Avatar
Default Re: (Chewy Built !)
only on the left side.
it really bothers me.
it slowly digging into the bumper because of vibration.
Old Jul 28, 2007 | 02:13 PM
1989CivicSi's Avatar
Dang, surprisingly I had this same problem. I had two fillers (one from my JDM SiR front), and another from a late model ZC with the SiR front (black). The red one from my genuine JDM SiR front didn't fit worth a damn, but the ZC late model black SiR filler went on like a charm.
Here's a pic of what I mean:
Nothing exhibited having being bent or pulled. Perhaps there were changes made to the filler pieces over the years? Because the SiR engine bay is physically longer than the USDM's...maybe a problem with different rad supports?
Hopefully this could help, but I'm really really high right now .
Old Jul 28, 2007 | 03:08 PM
Zaakro's Avatar
Default Re: (1989CivicSi)
I didnt have a problem with mine. but I know mine came from a base model
Old Jul 28, 2007 | 04:15 PM
DIYMIKE's Avatar
Default Re: (Zaakro)
hahah this is nuts.
something else over looked in the ef9 world.
so....
ZC filler piece along with ZC TBAR???
Old Jul 28, 2007 | 04:18 PM
DIYMIKE's Avatar
so this is from my other post about sir hoods flying up on them
<br/>Shot at 2007-07-28
if you notice #2...
if this is true.... you can't use 90-91 front fillers
Old Jul 28, 2007 | 09:40 PM
I'm straight now...^ exactly what I said heh. I used the EF7/EF3 T-bar along with my late model filler to get what I have above . The real EF9 SiR filler piece wouldn't work for me with either the EF3/EF7 t-bar or the USDM t-bar.
gapergurlie_18
Apr 28, 2010 06:25 PM
EG type GTR
Jun 25, 2006 06:51 PM
cloproductions
Nov 3, 2002 10:07 PM
TurBoXBirD16
Sep 4, 2002 10:47 AM
mr2
Mar 6, 2002 02:15 PM
