Here Goes....probs with zc swap
Old Jul 27, 2007 | 10:07 AM
quintb2000's Avatar
Default Here Goes....probs with zc swap
Ok, i started a topic the other day about having problems with my zc swap into my 93 civic......everything did bolt up fine but i found i am left with an extra plug on the harness.....according to the manual it is either the air temp sensor, or one of the two solenoid plugs for the intake exhaust but the problem is.....i only have 2 sensors to plug into on the back of my exhaust manifold......can someone help???
Old Jul 27, 2007 | 10:13 AM
95vxtealhatch's Avatar
Are you throwing codes, or does it not start? I fail to see what the problem is here.
Old Jul 27, 2007 | 10:15 AM
BlackoutVTi's Avatar
Default Re: (95vxtealhatch)
What OBD is your wiring harness, compared to the engine?
Old Jul 27, 2007 | 10:29 AM
quintb2000's Avatar
When i think i put them on correctly no codes throw.....but i have one leftover sensor plug......starter turns but the car just won't start......
Old Jul 27, 2007 | 10:30 AM
quintb2000's Avatar
Default Re: (BlackoutVTi)
harness is odb1 just like the engine.....
Bern0428
12
Jan 11, 2013 09:49 AM
~sp33~
12
Mar 12, 2011 08:20 PM
SC-MK1
May 22, 2005 08:51 PM
HondaKPX
Aug 19, 2004 08:20 PM
gregv
Sep 11, 2002 03:24 AM
