Honda S2000 Honda S2000
Change brakes
Old Jul 27, 2007 | 10:04 AM
Eddie99's Avatar
Default Change brakes
Hey. Is there anyone know any important tools I should get to change the brakes on the S2000? This is the first time I will do it my self on this car, i have done it before though on my dads car.
I don't know if the brakes on the S2k is different mounted or is it as easy to change the brakes on the S2k as it is on all other cars?
Old Jul 27, 2007 | 10:13 AM
veilsides2000's Avatar
Default Re: Change brakes (Eddie99)
Basically the same as other cars. Get a "C" clamp so you can push the piston in your calipers back. And when you bleed your brakes, make sure you start with the wheel furthest away from the master cylinder and work your way in.
good luck
Old Jul 27, 2007 | 10:18 AM
b20integrapower's Avatar
Default Re: Change brakes (veilsides2000)
basic metric socket-wrench set, c clamp, BIG screw driver for rear pistons(or the tool made for the job, dont know what its called), grease for the back of the pads and some mechanical ability.
Old Jul 27, 2007 | 10:24 AM
Mr. Projekt's Avatar
* B A N N E D *
Basic tools as mentioned, and you won't need to bleed the brake lines if you don't open them.
umair
Oct 18, 2011 08:40 AM
JDMPR
Jul 18, 2009 02:09 PM
knmwood
Suspension & Brakes
Nov 15, 2008 05:56 AM
budomove
Oct 29, 2007 03:21 PM
ComoTeGusta
Nov 28, 2004 12:46 AM
