91 accord drive belts replacement
Old Jul 27, 2007 | 08:11 AM
idewson's Avatar
Default 91 accord drive belts replacement
I'm trying to replace the alternator and power steering pulleys. i'm having trouble loosening the tension in the belts enought to get them off. I've loosened the pivot bolts and adjustment bolts too but neither moves enough. The altenator doesnt even move at all. It looks like the alternator would move if I removed the pivot bolt but I can't because of the power steering pulley.
I know this shouldnt be this difficult. can you help me out?
Thankz
Old Jul 27, 2007 | 04:15 PM
hondadude's Avatar
Default Re: 91 accord drive belts replacement (idewson)
You do know there are long threaded 10mm bolts that create the tension/slack,look under the P/S pump, and in front of the Alt
Link to pic
http://img248.imageshack.us/my...o.jpg
Old Jul 28, 2007 | 06:51 PM
idewson's Avatar
Default Re: 91 accord drive belts replacement (hondadude)
yeah but either the alternator or the p/s pump do not move enough for me to get the belts off.
Anyway, I have the belts off now but I can't get them back on! Are there any tricks? There isnt enough movement for me to get enough slack to get the belts on. and I know your not suppose to pry them on. what do I do?
Old Jul 28, 2007 | 06:53 PM
phootbag's Avatar
Try turning the adjustment bolts out more.
Old Jul 29, 2007 | 03:02 PM
idewson's Avatar
Default Re: 91 accord drive belts replacement (phootbag)
they are completely off! I still dont have enough movement to get the belts on. I'm supposed to then put the belts on the crank pulley last and slowly turn that to get the belts on right?
Old Jul 30, 2007 | 08:15 AM
bseriescrxsi's Avatar
i just completed this on a 91 accord actually....on top of loosening the front adjuster bolt
theres a 12mm bolt under the power steering belt spindle that you have to loosen(on the right side, next to the wheel well) and the power steering pump should pivot down.....this is also true for the alternator
Old Jul 30, 2007 | 05:58 PM
hondadude's Avatar
Some mental midget turned the backside[head] of the tension retaining nuts and put the tabs into the slots
si92prelude
Jun 24, 2010 12:04 PM
invision
Apr 19, 2009 09:49 AM
dhn
Mar 25, 2006 08:48 AM
omeara7
May 2, 2004 07:58 AM
