h22 stroke
Old Jul 27, 2007 | 04:46 AM
ezza's Avatar
Default h22 stroke
im planning to boost my h22a, naturally a bigger displacement would yeald higher gains with fi. if i use a f22 crank and h23 rods apparently it increases the displacement to 2.3 (not done the exact calculations yet) but would the power gain warrant the extra strain on the engine?
BTW i would have the crank balanced and knife edged
Old Jul 27, 2007 | 05:50 AM
Lubo_25's Avatar
Default Re: h22 stroke (ezza)
you dont need to stroke the motor for gains man youre forced induction...lol for what 40-50hp? and no knife edging cranks on a turbo motor you will need that counterweight strength and momentum...but thats my .02 cents
Old Jul 27, 2007 | 06:05 AM
Bense's Avatar
moving this to prelude. There are more h22 tuners in that forum that will be able to offer you better advice.
Old Jul 27, 2007 | 07:00 AM
ezza's Avatar
Default Re: (Bense)
ahh, so knife edge'd crank good for na only? i think i will keep the stock stroke actually, i want the engine to retain some of its higher revving quality's.
thnx bense
Old Jul 27, 2007 | 07:06 AM
NirVTEC's Avatar
Default Re: (ezza)
Why not sleeve to 89mm?
Old Jul 27, 2007 | 07:21 AM
ezza's Avatar
Default Re: (:=:NirVTEC:=:)
if i sleeved to 89mm what power gains can i expect and will this lower the highest potential psi?
Old Jul 27, 2007 | 07:42 AM
93h22a1vtec's Avatar
Default Re: (ezza)
borin it out to 89mm puts you around like 2280 or something like that for displacment. so you will have that "2.3L" that you want and still have the stock stroke.
Old Jul 27, 2007 | 10:36 AM
Mikey3000's Avatar
Default Re: (ezza)
there's really no need for that extra work when going turbo unless you are really serious about racing and doing everything possible to get the edge on the competition. people are making 800 hp on stock bore/stroke turbo motors. i made 680 hp @ 28psi, stock bore and stroke. i can make more the only thing holding me back is my turbo size and map sensor (3bar).
Old Jul 27, 2007 | 01:05 PM
Lubo_25's Avatar
Default Re: (ezza)
exactly youre always safer boring out the cylinders to 89mm for more displacement then ****** with the rs ratio...chicks dig the revving... i mean typically you leave more cylinder meat for hg clamping but if the machine work is **** on 89mm will be reliable...
Old Jul 27, 2007 | 03:11 PM
ezza's Avatar
Default Re: (Lubo_25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">there's really no need for that extra work when going turbo unless you are really serious about racing and doing everything possible to get the edge on the competition. people are making 800 hp on stock bore/stroke turbo motors. i made 680 hp @ 28psi, stock bore and stroke. i can make more the only thing holding me back is my turbo size and map sensor (3bar).</TD></TR></TABLE>
fair point
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 &raquo;</TD></TR><TR><TD CLASS="quote">chicks dig the revving... </TD></TR></TABLE>
fair point
Old Jul 27, 2007 | 03:42 PM
gogunkergorilla's Avatar
not that important on a drag car....but if its a street car, you will probably like the midrange you get with the 95mm crank.
fukenricen
Dec 25, 2009 03:37 AM
cvcrtonv
Feb 8, 2008 07:14 AM
aimmotorsports
Nov 9, 2006 02:24 PM
sleepystyle
Oct 18, 2005 06:55 AM
DLB1994
Dec 3, 2002 12:07 PM
