Almost no brake pedal
Ok guys, just got a sedan, trying to figure out whats up wiht the brakes. They work, but not the best. Its a Dx so it has disks up front, drums in the rear. When you first push the brake pedal when coming to a stop it has some nice pressure, then gradually goes to the floor with almost no stoping power. I checked the res. and its full. Im thinking air in the lines somewhere but just wanted more opinions on it.
yeah. im having same problem, for my crx, i know what, could b teh brake clyinder thingy, but iono. ima let my dad take a look at it hahah. if i find out whats teh problem tomorro. ill let u know .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rd91SiB18ls »</TD></TR><TR><TD CLASS="quote">Bleed them if there still bad check pads,then the master cylinder.
Good luck.
I had the same problem and it turned out to be the master cylinder.
Good luck.
</TD></TR></TABLE>I had the same problem and it turned out to be the master cylinder.
FourthGenHatch
15
Oct 5, 2002 07:53 PM
