help: rust on the lining between my room and my rear window
Old Jul 26, 2007 | 03:54 PM
cilvia's Avatar
Default help: rust on the lining between my room and my rear window
the rust on my roof is rusting pretty bad where water would leak inside my car interior...can i just break off all the rust and sand it down and fill it with bondo?? will the rust still overtake my roof?? i know i got to remove the window to do a proper repair but i dont have the time to do all that soo i need another option...someone else told me fiberglass would be good...but i dont know how i would get between the linings...anyone have their suggestions?? thanks
Old Jul 26, 2007 | 04:00 PM
umop-apisdn's Avatar
Default Re: help: rust on the lining between my room and my rear window (cilvia)
Bondo is not meant to span across openings, only to build up uneven surfaces. Do it the right way and have someone weld in new metal, grind down the welds, then bondo. Then primer and paint.
Old Jul 26, 2007 | 04:14 PM
sc4dr's Avatar
What kind of car is it, and where exactly is the rust? That sounds odd.
Old Jul 26, 2007 | 09:44 PM
cilvia's Avatar
Default Re: help: rust on the lining between my room and my rear window (sc4dr)
but for a cheapo fix will it work?? when would the rust re-appear
Old Jul 27, 2007 | 03:24 PM
sc4dr's Avatar
Take pictures so we know what you're talking about.
Or you could just hack it up, because thats probably what your gonna do anyway
WolfDragon
Apr 26, 2018 10:41 PM
fryman
13
May 20, 2010 10:25 PM
9hatch6
May 20, 2006 01:20 PM
Ronin Integra8
Dec 17, 2002 10:49 AM
