1989 CRX, WHAT WHAT SPEAKER SETUP!?!? HELP ME OU!
Old Jul 26, 2007 | 03:24 PM
Freezen's Avatar
Default 1989 Honda CRX, Speaker Setup im noob at this!
http://www.bestbuy.com/site/ol...26861
http://www.bestbuy.com/site/ol...80920
http://www.bestbuy.com/site/ol...87569
http://www.bestbuy.com/site/ol...97748
or
http://www.bestbuy.com/site/ol...97803
what you guys think in a crx? I need some opinions cuz I might do it in the next week or so.
Modified by Freezen at 8:56 AM 7/28/2007
Old Jul 26, 2007 | 03:26 PM
JJ's civic's Avatar
Default Re: 1989 CRX, WHAT WHAT SPEAKER SETUP!?!? HELP ME OU! (Freezen)
i'm nnot looking ast the site i'm jsut lazy today sorry lol. but i have a alpine head unit. 1 12 sub and a 800 amp and that' plenty enough to shack the car lol. it's a hatch you dont need much.
Old Jul 26, 2007 | 03:42 PM
Freezen's Avatar
Default Re: 1989 CRX, WHAT WHAT SPEAKER SETUP!?!? HELP ME OU! (JJ's civic)
haha I think my setup my bump then lmao
Old Jul 28, 2007 | 06:14 AM
Freezen's Avatar
bumb ^^^ Help me out guys! lol
Old Jul 28, 2007 | 08:02 AM
fcm's Avatar
fcm
Old Fart
Although the Alpine equipment you have picked out is all good, there are some problems.
First, the speakers, SPR-17C are over-sized 6.5", your car takes standard 6.5", so if you want to use them, some custom work is needed to install them properly.
The sub, SWR-1042D is a 500W continuous speaker, neither of the amps you looked at have enough power to drive the sub properly, you really need something in the 500W-600Wx1 into 2ohms range, or there is a potential to damage the sub, with that said, it will work with a 1x200W into 2 ohm amp, but you will have to be careful not to drive the amp into continuous clipping.
The sub box will work, recommended gross volume, [sealed box] for the sub is .5 - .8 cuft, although I would "beef up" the box with some bracing.
You have linked 2 amps a 4x40W RMS into 4 ohms and a 1x220W RMS into 4 ohms or 1x400W RMS into 2 ohms
The mono block could be used to power the sub, although a little underpowered.
The 4ch could be bridged into a 2ch amp and drive the 2way speakers, although also a little underpowered, 2x80W RMS into 4 ohms, [the speakers are 100W continuous. 94
Old Jul 29, 2007 | 12:08 PM
Freezen's Avatar
Default Re: 1989 CRX, WHAT WHAT SPEAKER SETUP!?!? HELP ME OU! (fcm)
What if I get the MRP-F250 (multichannel) amp in the link above for the 6.5 speakers around the car then hook the 10" sub with this amp:
http://www.bestbuy.com/site/ol...97968
or
http://www.bestbuy.com/site/ol...26929 which I know would work its got good continuos power just expensive
would that be a safe choice?
Modified by Freezen at 1:31 PM 7/29/2007
Old Jul 29, 2007 | 02:49 PM
JJ's civic's Avatar
one thing about the speakers is you need to be aware of how deep they are. because you need shallow 6.5s or like i have 5.25 in a adapter plate.
Old Jul 29, 2007 | 02:56 PM
Freezen's Avatar
the site says the speakers fit so when I go to get them installed ima take it out on them if they expletive up and theirs nothing they can do about it haha
Old Jul 29, 2007 | 03:00 PM
fcm's Avatar
fcm
Old Fart
What do you mean, "6.5 speakers around the car" do you have two sets of the Alpine SPR-17C?
Both the amps you link would do the job, although 300W is way more over-powered then you need to be, you will have to be very careful with the amp gain, I would still look for something that makes 1x500W-600W RMS into 2 ohms.
If the 4ch is going to be bridged into a 2ch to run just a set of front speakers, then it will work just fine, but again, why not just find a 2ch, 2x100W-125W into 4 ohms?
If you are talking about 4 speakers that's another issue, and you did understand that the Alpine SPR-17C speakers will not fit the stock speaker brackets/housings. 94
Old Jul 29, 2007 | 03:49 PM
Freezen's Avatar
what I think ima do is have the pair of alpine speakers hooked up to the 75w multichannel amp in the back and get the alpine 10" sub and stick it back their to ofcourse haha, anywho FCM since you seem most knowledgable ijn this field do you think you can give me the best speaker/amp combo from the list I gave you it would help me greatly! thanks Pimpin! lol
Old Jul 29, 2007 | 04:06 PM
fcm's Avatar
fcm
Old Fart
If it's a choose between what you have linked then the two last amps you linked would be the ones I would use. 94
Old Jul 29, 2007 | 04:10 PM
Freezen's Avatar
so basically the 75w mulitchannel and bridge it to either of the last mono amps? does it matter with either of the power on the mono amps or are they both ok to be linked to and enough to drive the sub?
just Touge
Oct 15, 2010 03:58 PM
91highryda
Aug 24, 2009 09:04 PM
Freezen
Jul 26, 2007 03:16 PM
Garrett
Sep 24, 2004 08:34 AM
OldSchoolCrxSiR
Sep 29, 2002 03:43 PM
