problems with hasport cable/hydro setup
In stop and go traffic, My clutch seems to get harder and harder to use until it is barely going into gears and the pedal is incredibly stiff. It seems that the cable moves around even tough the hasport kit is adjusted as well and adjusting the clutch from the cable as well. Has anyone had a similar problem with the cable to hydro conversion kit from hasport?
Your clutch cable might be going out on you. It happened to me, I replaced it with an OEM Teg cable and haven't had any problems since.
redDAinteg
Nov 20, 2008 02:01 PM
