D series trans makes grinding noise with fidanza LWF
I just had a 7.5 lb fidanza flywheel installed along with a exedy oem replacement clutch on my 99 Civic ex and have drove on it for 5000 miles and now the trans make a noise when I let off the clutch, its like a grinding noise. The sound only persists when I let the clutch off and especially when I am coasting in gear. Is there a problem with my flywheel?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by $nahk »</TD></TR><TR><TD CLASS="quote">I just had a 7.5 lb fidanza flywheel installed along with a exedy oem replacement clutch on my 99 Civic ex and have drove on it for 5000 miles and now the trans make a noise when I let off the clutch, its like a grinding noise. The sound only persists when I let the clutch off and especially when I am coasting in gear. Is there a problem with my flywheel?
was your pilot bearing replaced when all this was done.
</TD></TR></TABLE>was your pilot bearing replaced when all this was done.
selectivebeef
Jul 1, 2003 08:27 PM
