97 Accord EX - Grinding sound when idling. Every 2-3min. for about 2sec.
Old Jul 26, 2007 | 12:25 PM
edro13's Avatar
Default 97 Accord EX - Grinding sound when idling. Every 2-3min. for about 2sec.
I have had my 1997 Accord for quite a while now and it seems to have always done this, but I tend to notice it more often now.
Anytime my car is on (idle or driving), every few minutes, the engine "pulls down" and grinds for about 1-2 seconds.
The lights dim and the engine makes a distinct lower pitched sound for this 1-2sec. duration.
Afterwards, everything is fine.
The engine acts like the AC was turned on for 1-2sec. but it isn't. The "pulled down" sound I mention is similar to when you turn on the AC. The lights dim a bit and the engine is under a greater load.
Has anyone ever seen this before? Is it normal?
A side note is that my AC doesn't work and hasn't for the last few years. I have never seen the AC condenser fan kick on, and the AC pump never seems to engage when I hit the AC button. It could be related... but this car has always done the "pull down" thing ever since I can remember (6+ years).
Thank you for any input!
Old Jul 26, 2007 | 07:41 PM
hondadude's Avatar
Default Re: 97 Accord EX - Grinding sound when idling. Every 2-3min. for about 2sec. (edro13)
open the hood and put a stethoscope on the dist housing, if it usually happens more often when the engine is warmed up thats where I'd look.
Old Jul 26, 2007 | 08:12 PM
phootbag's Avatar
Does the cooling fan come on at the same time you hear this symptom?
Old Jul 26, 2007 | 08:20 PM
ujhonda's Avatar
"The lights dim and the engine makes a distinct lower pitched sound for this 1-2sec. duration. "
I would also check alternator bearing and belt -
Old Jul 26, 2007 | 08:27 PM
dwayne1413's Avatar
Default Re: 97 Accord EX - Grinding sound when idling. Every 2-3min. for about 2sec. (ujhonda)
Actually, i have a 97 ex as well and i get that sound too. i dont know if i would consider it grinding though. It only happens when i dont give it enough gas getting out of first or if i turn the ac on. but i can hear that sound in my head right now, its horrible.
civitas
10
Mar 26, 2015 04:52 PM
sweetazzwhine
Aug 24, 2013 06:34 AM
SLCAccord
Apr 20, 2007 05:41 PM
accordexdrvr
Sep 26, 2006 12:44 PM
dan1116
Jul 25, 2004 11:07 PM
