88-91 clusters and dash's
So if I am correct in the years 88-89 CRX, Civic hatch, Sedan they used a smaller gauge cluster and top plastic gauge cluster hood/cover. Then in 90-91 Honda used a bigger cluster. Thus you can install a 99 si cluster or 94-01 integra gauge cluster. That fits pretty good right?
I have to do a dash swap on the old sedan soon, so I am looking to go with the 90-91 crx dash.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">So if I am correct in the years 88-89 CRX, Civic hatch, Sedan they used a smaller gauge cluster and top plastic gauge cluster hood/cover. Then in 90-91 Honda used a bigger cluster. Thus you can install a 99 si cluster or 94-01 integra gauge cluster. That fits pretty good right?
</TD></TR></TABLE> No need to get the newer (90-91) dash, all you need is the cluster bezel. This bezel has the ovaluar shape pertaining to the top of the cut out for the cluster, compared to the older (88-89) which is primarily rectangular.
Also some custom fabrication should be involved pertaining to the parts in which the cluster screws into and is held to...
more information here regarding the EM1 cluster swap http://www.ef-honda.com/main/viewtopic.php?t=1400
Also some custom fabrication should be involved pertaining to the parts in which the cluster screws into and is held to...more information here regarding the EM1 cluster swap http://www.ef-honda.com/main/viewtopic.php?t=1400
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">so the crx dash it doesn't matter then with. i do know for fact the sedan dash is fixed.
</TD></TR></TABLE> I am confused with your response, but you can place a 90-91 bezel on an 88-89 dash "crx" for sure, and swap in the cluster
slammedcivicsi
Mar 2, 2006 12:22 PM
hahahahhah
Apr 6, 2004 09:02 AM
