1993 accord ex-Steering wheel shake at high speed
For speed above 60-65mph, the steering whell seem to shake a lot. What could be the reason? I did balancing of tires. Timing belt service done a month ago.
What could be the reason? One tech guy told me that it can be worn axle inner joint or something. Might need to replace both axle. i have no clue. There is no noise from turning due cv etc.
Can anyone kind help?
my mechanic chanegd the rotors the quick way by separating the hub and its been getting worse over a few months. cause everything feels solid and theres no play anyware. changing just the pads won't wreck the bearings
As I posted in my first post, someone told me that it could be worn axle inner joint or something. I am not very good at this mechanic thing. is it same as Cv joint or shaft?
Buying axle must be expensive. any ideas?
I had my brake rotor resurfaced and brake pad replaced lately. Could that be the source of problem if the problem is indeed in bearings?
Sorry, i am kind of lost here. Mechanics are expensive. If I take anywhere, they don;t spend time to diagnose but just want to change things. i f I tell them this is the problem, they will say, ok go change axle. then I will see problem is not fixed and only money is gone. Later something else will comeup. In my town I am kind of fed up with mechanic shops.
One more thing I must clarify is that by steering shake I meant that its kind of rocks left-right. Its not inward outward vibration thing.
Tires can be out of round or have belts separated and balancing will have no effect on them because the tire balancer can't reproduce the force and load under use. Move your fronts tires to the rear and see if the shake moves to the seat of your pants instead of the steering wheel.
yeah that happened to my 1998 honda accord ex coupe i changed my rotors nd brakes nd now it stopped i did it today
i have a 1995 accord and the sterring wheel shakes at speed of 65 and on, and also while getting of a ramp when slowing down. like a month ago a got new tires(including balance) on stock rims. the next day i took the car to get the entire service= alingment, brakes and pads check. when i got it back it stop shaking until now a month later.
i think it could be the axles that are wearing out. can anyone help?
I have smiler problem - this is what I did so far....pls read it may help you too...
https://honda-tech.com/zerothread/2048015
Can anyone know what is axle inner joint ? Is it same as cv joint? One mechanic told me inner axxles are worn out and that causing problem. Now, honda dealer gave me quote of $406 for replacing two axle. But can I get cheaper with Advanced auto parts or autozone ? I know they sell cv joint. I am not sure if they sell axle, specially what is inner axle?
There is no inner axle. There is the inner tie rod, which might be your problem, and I am 80% positive it isd the problem on my 1993 Accord SE with 200K miles. What I have replaced in the last 2 years.
Front Rotors / Pads / Calipers
Rear Rotors / Pads / Calipers
Master Cylinder
Front Tranny Mount "Strut Mount"
Both Front Axles
4 new tires
Both Upper Control Arms
Both Tie Rods Ends
Both Ball Joints
Sway Bar Endlinks - Bushings
Alignment
Only thing that is left is wheel bearings and inner tie rods
The car does not make the notrious howl of the wheel bearings. Yet, the inner tie rods do not seem loose, yet I know they have 200K on them. I do not want to replace them as they will be a HUGE PITA
But that is probably your problem.
Master Cylinder
Both Front Axles
4 new tires
Both Tie Rods Ends
Both Ball Joints
Alignment
If your rotors are worped then they will also do the same thing, If your steering wheel shacks when you alsop hi the brake then its your rotors, if not then more then lickely its going to be your inner tir rod and if thats it then your going to need an alignment after aswell
i have a 1995 accord and the sterring wheel shakes at speed of 65 and on, and also while getting of a ramp when slowing down. like a month ago a got new tires(including balance) on stock rims. the next day i took the car to get the entire service= alingment, brakes and pads check. when i got it back it stop shaking until now a month later. it also pulls itself to the side(left or right) when coming to a stop.
can the tie rod be the reason for this, because i already try everything else. if so, how much would it cost???
im also going to need another alingment?
not really, only when im slowing down at any speed. and at times it shakes so hard that the entire front side of the car feels like if i was going off-road or something alike.
freezy
11
May 9, 2011 02:19 PM
