TODA C Spec's or C Spec + !!
I posted a while back about having bought Toda cams from Toda Japan an having the Intake cam on my C Spec to have a different lift on one of the secondary lobes...well I was finally able to Scan the Damn sheet( No thanx to WinDOHs XP ) ....So I just thought that I would share this info with you guys...
Take a look at the intake specs. .
UPDATE PIC's
If you take a look at the right secodary lobe you can see the small height difference.
[Modified by JDM_DOHC_SiR, 7:49 AM 6/12/2002]
[Modified by JDM_DOHC_SiR, 5:59 PM 6/13/2002]
did u ever mic the lobes like i said to?
Should be a .4mm difference in size
Actually I did but it cam out to more like .5 ...?? I'll take one more Picture today and mic' them so you can see
wanna send me the intake cam to test?
Ummm errr Sure if you want to come to Japan and tune my Hondata on a PWO ecu to wore up to 9500Rpm and work with the C spec's
PR3/Pw0 arent good past 9000. You know that.
Austin
Yep...which is why I've been trying for the last 2 weeks to get in touch with Kenji to purchase an adapter harness for him.
Austin
Austin
So have you gotten your spec C's in already? I'm sure someone from Toda could have it tuned in short time. Are you using Power FC or Hondata? I know Toda seems to like use PowerFC to tune on there cars as it's listed with couple other makes they have.
I'll just stick with my good old KS Rom untill I can get the Hondata issue's worked out
