Old Mar 25, 2015, 11:46 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Vibration at Idle - Bad Motor Mount?
Old Jul 26, 2007 | 02:27 AM
m1ndless's Avatar
* B A N N E D *
Default Vibration at Idle - Bad Motor Mount?
Latley I have been noticing a slight vibration when I am at idle RPMs, espically at drive thru's and at Red Lights.. I can really feel the vibration in the steering wheel, it feels my car "shivers" which is really odd. I figure its one of my motor mounts, but I am not sure, how do I go about checking them? Are they easy to locate once my car is jacked up or what?
Could anything else be causing it? I notice it more often when my AC Is on, not sure if that has anything to do with it.
Old Jul 26, 2007 | 03:09 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Vibration at Idle - Bad Motor Mount? (m1ndless)
try checking your front motor mount first, it's probably the most common mount to break. To check it, just visually look at the rubber of the mount and see if it's broken.
Old Jul 30, 2007 | 06:47 PM
heirfaus's Avatar
1989 Honda Accord LXI Hatch
I have this similar problem. My steering wheel vibrates when car is stopped idling in drive or reverse. Does not do it in neutral or park or when driving down the road.
I remove the front hydraulic mount and it was split in 2 pieces. I put in a new one and it seems the vibration got a little worse.
Any ideas???????????????????
Old Jul 30, 2007 | 07:01 PM
dwayne1413's Avatar
Default Re: (heirfaus)
Deffinately a motor mount. See if you can locate the mounts and check them, should be 3 all together. Sometimes they just go get old and go bad. Sometimes just bottoming out or hitting a curb could do it. I have personal experience with that
Old Jul 30, 2007 | 07:33 PM
02 accord's Avatar
At freeway speeds, when you let off the gas or get back on it, if you feel a jerk, the mounts are bad. How many miles do you have on the car?
Old Jul 30, 2007 | 07:38 PM
heirfaus's Avatar
186k miles.
I just bought it and am fixing it up. I replaced the torque strut bushings and front hydraulic mount. I know there is a weird little rectangle shaped bushing thing under the transmission and I need to replace the mount at the front of the motor.
It does jerk at freeway speed when letting off or pushing hard.
I will try and replacing the other 2 pieces of rubber.
Old Jul 30, 2007 | 07:42 PM
Gsir8's Avatar
I have a similar problem, my car does vibrate and idle, and I'm not sure if this is the same problem but it does alot once I get up to about 80. And I know my frount motor mount is shot, but would changing it help these problems?
361 accord's Avatar
this seems an approprite place to ask
whats that "test" u do to check if the mounts are bad?
Old Jul 30, 2007 | 07:44 PM
02 accord's Avatar
Default Re: (361 accord)
Visual inspection, seeing if it jerks at freeway speeds (as I mentioned)
Old Jul 30, 2007 | 07:45 PM
361 accord's Avatar
Default Re: (02 accord)
no i meant the one where u hump the car or something
Old Jul 30, 2007 | 07:47 PM
02 accord's Avatar
There is no "car-humping motor-mount test" that I know of.
Old Jul 30, 2007 | 07:49 PM
361 accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">There is no "car-humping motor-mount test" that I know of.</TD></TR></TABLE> yeah u rock the car back and forth or something, sounds like car humping to me dude, i know ive humped my car, i couldnt help it, it looked so good
Old Jul 30, 2007 | 07:51 PM
heirfaus's Avatar
Default Re: (Gsir8)
The front motor mount(the one in the front of the car, not the front of the motor) is hadraulic(liquid filled and is supposed to suppress vibration. If you know it's shot replace it. This is where I started and it looks like it was only the beginning. I did notice less of a jerk putting it into drive from neutral.
02 accord's Avatar
You can put it in park (auto) or in gear (manual) and rock the car back and forth to see how much the engine twists. Or you can start the motor, put it in gear, and while holding the brake, give it gas. That will twist the motor the same as rocking (humping) it. Using the ebrake works well for this especially with automatics. Set the ebrake, put it in gear, and stand next to the engine bay (in case something goes wrong so you don't get run over), give it gas, and watch the engine/mounts for excessive movement.
emmaturecb7
Jan 10, 2008 04:56 PM
josedc5s
11
Jun 19, 2007 08:22 AM
ogre1
Jan 31, 2006 09:01 AM
khmboostedeh2
14
Dec 20, 2004 08:16 AM
h22dx
Feb 9, 2004 07:46 PM
