Am I hearing detonation???
Old Jun 10, 2002 | 12:40 PM
HXMan's Avatar
Default Am I hearing detonation???
I got the car boosting a little but I seem to hear a rattling sound coming from the engine. I'm letting it cool down some and I am going to pull the plugs to see what they look like.
I don't hear the rattling out of boost, but it is there as soon as I begin to boost. It is pretty loud, so I am thinking it could be the WG opening up? All I have controlling it is an MBC, so I am hoping the WG is opening before getting to full boost and that is the noise I am hearing. I hit maybe 5 psi.
Fuel setup as follows.
450cc injectors
AEM fuel rail and FPR
Untuned Hondata 3b with a program that was tuned for another car. (Fmax, 440cc injectors, b16)
Walbro High pressure intank
Base fuel pressure at 50psi.
Oil is leaking, so I'm not going to drive it too much. Othen then those two problems it seems great!
Old Jun 10, 2002 | 12:43 PM
technine's Avatar
Default Re: Am I hearing detonation??? (HXMan)
rattling noise from engine bay and no loose bolts = detenation.
How loud is it and does it go away with higher rpms? What grade gas are you using? Try some octane booster or and maybe bring your timing back a bit.
Old Jun 10, 2002 | 12:45 PM
HXMan's Avatar
Default Re: Am I hearing detonation??? (technine)
It is pretty loud, easy to hear. I was afraid to bring the rpms up high.....I got into the throttle at around 3000 rpms and let them go up. I didn't give it full throttle, but once it started to boost it seemed like it was making that noise. I have 93 octane in there.
Oh, how can I bring back my timing?
Old Jun 10, 2002 | 12:46 PM
sgT's Avatar
sgT
more than likely its the wastegate
when you hear the noise does the engine hesitate or act funny?
Old Jun 10, 2002 | 12:50 PM
HXMan's Avatar
Default Re: Am I hearing detonation??? (sgT)
Nope, seems to act fine.
Thought I would add some color to this thread.
[Modified by HXMan, 4:20 PM 6/10/2002]
Old Jun 10, 2002 | 01:30 PM
TurboSedan's Avatar
New User
Wow Steve you have a crazy # of posts!
Old Jun 10, 2002 | 01:54 PM
tonydatyga's Avatar
if not wastegate or loose bolts... it might be a little pre-ignition? that would follow your descrip of starting when you get boost.
Old Jun 10, 2002 | 02:51 PM
flip1199's Avatar
does it sound like someone is dropin marbells in your engine???
Old Jun 10, 2002 | 03:02 PM
HXMan's Avatar
Default Re: Am I hearing detonation??? (flip1199)
Hmmmm....what could fix this? Colder plugs? Different plug gap??
Its hard to tell....wish there was someone around here that really knew....
Old Jun 10, 2002 | 03:08 PM
DragII's Avatar
prolly the wastegate. are you using the turbo for your vac source to the wastegate?
Old Jun 10, 2002 | 03:09 PM
HXMan's Avatar
Default Re: Am I hearing detonation??? (SuperDragII!!!)
Yes.....
Old Jun 10, 2002 | 03:21 PM
shadowdawn's Avatar
I might as well ad to this post. Sometimes if I just start to get into boost I hear one quick "knock". Only thing is its VERY infrequent.. seems like it only happened mabye 4 times total..... Doesn't sound like marbles more like when a big rock hits the bottom of your car or something, and it only happens once in blue moon... Its possible its something moving in my trunk hitting something else mabye? I just wanna be sure its not detonation...
Also no hesitation or otherwise weird engine response when its heard.
Old Jun 10, 2002 | 03:29 PM
HXMan's Avatar
Default Re: Am I hearing detonation??? (shadowdawn)
I am hearing it everytime. Here is a pic of my plugs...they look good. I couldn't see any metal flakes on them.....
Old Jun 10, 2002 | 03:38 PM
-=TWITCH=-'s Avatar
How long have those plugs been in the car? they look like they have been a little hot!
This is a pick of a normal plug!
[Modified by -=TWITCH=-, 4:39 PM 6/10/2002]
Old Jun 10, 2002 | 03:40 PM
DragII's Avatar
Default Re: Am I hearing detonation??? (-=TWITCH=-)
yeah, looks like you ran lean on the plugs.
also, tee your wastegate actuator line into the fpr vac line. my deltagate always opened up @ 0psi until I did that.
Old Jun 10, 2002 | 03:49 PM
shadowdawn's Avatar
Mine have that flaky crumby look just a tad... but I know I'm leaning out a bit at high rpms due to crappy stock injectors.. even with a 12:1 fmu the stocks just can't last long or put out with the stress of 100+psi of fuel pressure....
Old Jun 10, 2002 | 03:50 PM
HXMan's Avatar
Here is a close up...maybe I am running a little lean. Doug at hondata told me what fuel pressure the program was tuned for......but I can't remember if it was 50 or 60 psi! I was running 50, guess I will jack it up.
Oh, here is a closeup.
Old Jun 10, 2002 | 04:40 PM
Sonny's Avatar
That plug looks good to me. That's how mine looked with my JRSC @ 8psi, dyno tuned, and safety tuned with the J&S to remove all detonation.
Sonny
Old Jun 10, 2002 | 04:51 PM
ion_four's Avatar
Default Re: Am I hearing detonation??? (Sonny)
Here's a good project, let's you know for sure if it's knocking...it seems cheesy at first, but is apparently BETTER than a J&S, if you know what you're listening for...I'm going to build one real soon, hopefully.
http://www.autospeed.com/A_0353/page1.html
Old Jun 10, 2002 | 04:53 PM
Sonny's Avatar
Default Re: Am I hearing detonation??? (ion_four)
Cool, but I'll stick with the tried and true, J&S.
Besides, once that boost kicks in, you'll be too busy listening to that burning rubber to hear anything in those headphones.
Sonny
Old Jun 10, 2002 | 05:11 PM
dustin's Avatar
detonation can sound different depending on the type...
When I had my car running lean on an hold Hondata map, I'd hear audible pinging from the motor and out the exhaust (easier to hear right when letting off the throttle to quiet exhaust noise but motor was still under load..) This sort of detonation sounded like a literal "PING PING" sound. Just like they say, dropping BBs in a coffee can.
Yesterday I had my car running on the AEM EMS b18c5 ignition map. Car was running crazy rich at full boost -- around 10.0:1 @ 7psi and about 12:1 @ 3-4psi.
When merging on the freeway at moderate throttle in 5th gear, I heard some decent detonation. However, it wasn't ping ping sound detonation. It was a ticking. Under accel I would hear random 'tick tick tick' sounds from the motor, only in boost. Sort of sounded like I was kicking small rocks up, but the sound was very clear and obvious.
I got the car home and checked the ignition map I had blindly installed. It was running about 32 degrees ignition advance @ 4psi heheh. Crazy. I guess this map is for a b18c5 w/ 9.2:1 compression as compared to my 10:1. I pulled a bunch of on-boost timing out of the map and the detonation is gone now. The knock sensor is only picking up light activity since the change....
So, yes, there is a good chance you are hearing detonation. You should be able to tell the difference between the wastegate opening and detonation...
HTH.
Dustin
Old Jun 10, 2002 | 05:43 PM
technine's Avatar
Well, sounds definitly like detonation to me. But hey, you don't have to take my word for it.
Sounds like bolts ratteling in your engine bay, but no bolts are loose=detenation and if it's loud=serious detenation
Old Jun 10, 2002 | 06:44 PM
HXMan's Avatar
Default Re: Am I hearing detonation??? (dustin)
Hmmm....anyone know where to get a JS knock meter or anything like that?
Old Jun 10, 2002 | 08:29 PM
HXMan's Avatar
Hope I didn't blow it up yet!
Old Jun 10, 2002 | 09:43 PM
lucas569's Avatar
long shot here but you running 50 psi fp w/ hose off? thats the correct way to read it, if not on me if you already knew this, cuase if your @ 50psi fp w/ the hose onyour really at about 40psi.
