Will a GT3076R fit on a Spoolin (Spoolin-type) log mani?
Yeah like the topic says. I know its a pimp turbo to put on such a simple type mani, but i just wanted to know. Im talking about the tubular logs, not the cast ones. Same applies to GT35R...will these fit. Ive already PM'd dc2, awaiting his reply. Any other experiences appreciated.
What compressor size?
E housing? S housing? Either way you will might have to shave the block webbing a little.
The E housing is a little bit more foregiving because the compressor housing is smaller.
I have a GT3076R .63 A/R with the E housing for this reason.
Yeah the compressor will be towards the drivers side, half radiator, 3" DP....no ac obviously. But the pic above i assume was just an example because that mani showed has a merge collector and is not a log. I just wanted to know if a GT turbo could fit on a log in a NO-AC config. Thanks, I will give it a shot.
DELshaneSOL
Mar 12, 2012 12:23 PM
