Solid CEL - Alternator Sp fuse keeps blowing
Old Jul 25, 2007 | 04:03 PM
90sedan's Avatar
Default Solid CEL - Alternator Sp fuse keeps blowing
So i just finished my drivers side wire tuck and i go to start the car and it only cranks, i can't hear the main relay click and the fuel pump is not priming.
- First i re-check all of my injector wiring 5 times, check the resistor box and look for any possible mishaps when wiring. Nothing, everything appears to be perfect
- All of the headlights, bumper lights, all work, so i know that my ground box is grounded well.
- After that i check for blown fuses, and the alternator speed sensor fuse is blown. I replace it, try and start the car up. I hear one click from the main relay and the car just cranks. No fuel pump priming, nothing.
- I've looked for the normal short-circuits, tried checking for wires that are grounded out. Looked at the O2 sensor, its not grounded out.
Does anyone know of anything else i should check? Any words of wisdom at all? bleh this blows...literally
Old Jul 25, 2007 | 04:37 PM
4thgenhtch's Avatar
Default Re: Solid CEL - Alternator Sp fuse keeps blowing (90sedan)
well obviously something in your wiring is a miss if this all happened after the wire tucking... Pull everything back apart something is grounding out in your work somewhere... GL!!
Old Jul 25, 2007 | 04:49 PM
90sedan's Avatar
Ya, I've started pulling it all out and trying to retrace everything.
Hopefully i figure it out sometime soon haha
gnxpro24
Nov 4, 2012 05:07 PM
Emmanuel2112
Mar 27, 2010 04:49 PM
civickiller
10
Aug 25, 2009 06:52 AM
jnemci
11
Jun 22, 2009 08:21 AM
DIYZane
Jan 15, 2008 11:27 AM
