2 questions on painting side skirts
Old Jul 25, 2007 | 09:53 AM
b18LS's Avatar
Default 2 questions on painting side skirts
Hi, Im just curoius, I sprayed my side moulding with a single stage paint in the custom mixed spray bomb cans. I was going to do my side skirts as well and have a couple questions. I wanted them to add an elastisizer, and they said you couldnt do that in a can, so I'll have to beleive them. Will this be an issue on the skirts? Also for those of you that have done yoru skirts, do you spray the area that will be underneath the car, or did you just mask that area and spray tthe exposed surfaces? Thanks.
Old Jul 25, 2007 | 10:03 AM
WihaSi's Avatar
Default Re: 2 questions on painting side skirts (b18LS)
Prep and paint the whole side skirt. I don't think that no flex additive will be that big of a deal on side skirts, you should be fine w/o it.
Old Jul 25, 2007 | 10:32 AM
b18LS's Avatar
Default Re: 2 questions on painting side skirts (WihaSi)
Thanks. I was thinking there wouldnt be any flex down there, but thought Id ask. Also, you say prep the whole skirt, are you suggesting painting the section thats hidden under the car as well? Seems like a waste of paint. I'd like to see type r skirts to see if theyre painted under the car as well. I figure it'd take some major abuse from stones snow etcc. under there. thoughts?
Old Jul 25, 2007 | 03:35 PM
vsmhatched's Avatar
you dont need any flex additive...besides most flex additives only last between 2-3 days so the paint will flex while your installing the bumpers, sides...etc, just clean them really good, and i also recommend spray them with a thin coat of Bulldog plastic adhesion promoter. Then spray with paint...should turn out pretty good
Old Jul 25, 2007 | 07:38 PM
luckii's Avatar
i heard just use a promoter then spray. if your using a spray can, it wouldnt matter. if it chips then respray ha.
Old Jul 26, 2007 | 03:01 AM
b18LS's Avatar
Default Re: 2 questions on painting side skirts (GreyDel)
Thanks guys, I'm going to go through with it. I've got Friday off and want a project to clear my head. I've got a decent primer that worked well on my side mouldings, so we'll see where that goes. Thanks for the advice. Ryan
gold_pwr_r4ng3r
Paint and Body
May 2, 2012 08:38 AM
IntegraBoy04
Apr 12, 2004 02:51 PM
nahledge 7
Aug 13, 2003 08:16 AM
Thrillhouse
Sep 16, 2002 11:03 PM
00b18b
Dec 24, 2001 09:59 AM
