distributor leak
Old Jul 25, 2007 | 05:57 AM
blackmfoggie's Avatar
Default distributor leak
I have a motor oil leakin from my distributor. I installed a new o-ring for it but that didn't fix the problem. I'm sure someone knows the answer to this
Old Jul 25, 2007 | 06:21 AM
JimBlake's Avatar
Default Re: distributor leak (blackmfoggie)
Does the oil leak outside of the distributor, against the head? Right where the O-ring is? Then you have to look for scratches in the surfaces where the O-ring seats.
It's also possible that the leak isn't really from the distributor O-ring. That O-rins sits in a bore formed by the last cam cap bolted to the head. It may be leaking out from the surface between the cam cap & the head. Use HondaBond or Permatex Grey for that.
If it's leaking INSIDE the distributor, coming out where the distributor cap sits, then you need a new distributor body. I don't think that internal shaft seal is replaceable.
Old Jul 26, 2007 | 02:52 PM
TAINO's Avatar
My 1994 accord lx have the same problem. I bought a distributor seal at PartsTrain.Com part number F2100-65416. I havent install it yet so i dont know if it work or not.
themiz816
Apr 28, 2013 07:16 PM
jchrm80
May 17, 2009 09:27 AM
blackmfoggie
Aug 23, 2007 12:09 PM
tca0bell
Oct 18, 2006 04:16 PM
sickvtec
May 21, 2004 05:41 PM
