WIRING VTEC F22B1
hello all,
i just had my motor swapped to a f22b1 vtec, but my old harness and ecu are for a non vtec f22b2, so i got the ecu for new motor and need help with wiring the vtec to the ecu. i see alot of diagrams for h22 but does anyone know how to with this motor....by the way its a 94 accord thanks
run the wire from the vtec solenoid to pin a4 at your ecu plug, then the vtec oil pressure signal wire to pin d6, ground the oil pressure anywhere. use a vtec ecu and will be set
Skeletor
Feb 23, 2003 05:15 PM
