Click/crunch sounds from brakes
Wondering if anyone ran into this before, Im getting a click/crunching sound 50% of the time when hitting the brakes, seems to stop fine. Any idea what it could be? 100% sure its brakes also, could one pad be loose making the sound?
Yes 100%, Its not a axel type of sound more like clunk when hitting brake, feels like the pad is shifting around almost. Think Im just going to do te front brakes this week and hope that was one of the issues
check to see if the little metal tabs are in there.
hard to imagine they came off if you havent touched them. but they often fall out when working on brakes.
also just check for loose bolts. and then checkfor loose balljoints after that. do a standard "wheel bearing test" by grabbing the wheel and shaking in all different directions. this action diagnoses bad balljoints more than any bad wheel bearing....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">check to see if the little metal tabs are in there.
also just check for loose bolts. and then checkfor loose balljoints after that. do a standard "wheel bearing test" by grabbing the wheel and shaking in all different directions. this action diagnoses bad balljoints more than any bad wheel bearing.... </TD></TR></TABLE>
Will do, thanks!
Will do, thanks!
swizz977
17
Jan 25, 2014 05:36 PM
Dracord
Oct 25, 2003 11:16 AM
