01 Coupe Window Master Switch Help
Old Jul 24, 2007 | 01:33 PM
dohc_chump's Avatar
Default 01 Coupe Window Master Switch Help
Any help on how to remove the armrest to access the master switch on an 01 coupe? From what I can see (which is very little) it looks like the armrest clips into the door lining, but I wanted to make sure before I try prying it off. Thanks in advance.
Old Jul 24, 2007 | 03:30 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 01 Coupe Window Master Switch Help (dohc_chump)
You shouldn't need to remove the armrest to access the switch. It should be one screw, and then pull back and up. Here is a TSB with pictures and instructions on removal.
http://www.tegger.com/hondafaq...e.pdf
Old Jul 24, 2007 | 04:12 PM
dohc_chump's Avatar
Default Re: 01 Coupe Window Master Switch Help (tech8)
thanks for the link! on the coupe door though, the armrest actually covers a few inches of the switch plate.... i'm hoping i can simply pop the armrest off, but when i tried last night i was afraid i was going to end up breaking something. i really don't want to have to take the whole door trim off to access the master switch and looking at a few diagrams it appears that there might be some clips holding it in place. thanks again!
H.N.F
May 18, 2016 07:42 AM
rkcarguy
Jun 26, 2009 01:48 PM
ridenslide65
Sep 28, 2008 07:29 PM
ramoneguru
May 25, 2006 07:39 PM
david90
Jun 7, 2004 03:25 PM
