Problem with breaks (Vibration )
Old Jul 24, 2007 | 01:32 PM
ezol's Avatar
Default Problem with breaks (Vibration )
I changed my font pads (with Honda pads) and rotors (from lordco) and I get a vibration when I break, this never hapened before. Do you think the new rotors are warped ?
thanks for the help.
Modified by ezol at 5:23 PM 7/24/2007
Old Jul 24, 2007 | 02:08 PM
MatterMatt's Avatar
Default Re: Problem with breaks (ezol)
No. Did you sand the wheel hubs smooth before putting the new rotors on? If not your rotors don't have a level surface to sit on and will runout/pulsate. If you did sand the hubs and still have a pulsation you could have a wheel bearing or hub issue.
Old Jul 24, 2007 | 02:16 PM
The-Kid's Avatar
I had my rotor changed and the first time i drove it, it kinda vibrates. It may take a while to get it set in. Maybe 500 miles? Drive it for a week. The Vibration should be constant.
Old Jul 24, 2007 | 02:20 PM
MatterMatt's Avatar
Default Re: (The-Kid)
If you feel a pulsation after replacing the rotors (the pedal shudders under your foot when braking) something is not right. Pulsation does not go away with break in and should not be constant.
Old Jul 24, 2007 | 02:41 PM
The-Kid's Avatar
Default Re: (MatterMatt)
Sorrry forgot to mention that. LOL
GSRacer1
Mar 10, 2011 11:54 PM
gohonda
May 14, 2009 02:40 PM
nikolai.
Nov 23, 2003 05:28 PM
PetroGuyX
Jun 26, 2003 02:10 PM
TsunamiZC
Oct 7, 2002 01:40 PM
