H11 fog bulbs
I just purchased a set of JDM yellow H11 bulbs from Luminics to replace the oem fog bulbs. For those of you who have done this before, what is involved in changing these bulbs out. I did not see any threads on the actual installation of the bulbs. How is access to the back of the fog lights? Do the oem bulbs just screw out? An installation guide would be nice, but any help will be appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tee Jay »</TD></TR><TR><TD CLASS="quote">its just as easy as regular lights.. unplug the wires then twist it off</TD></TR></TABLE>
That's what I thought. What about accessing the fogs to remove the bulbs? Does the bumper have to come off, or can I get to the bulbs from underneath?
Remove the plastic cover under the bumper and you can access the fogs. Unless you have a really small head, jack up your car, put jacks stands under it, remove as many of the assorted black clips as needed.
step 2 in the link shows the clips
http://www.collegehillshonda.c...r.pdf
Remove the Black plastic splash shield under the car. Need to remove about a dozen clips (pull up the center piece to release the clip and then pull the clip), and 2 screws (one on each side of the splash shield). That should give you enough space to get in and replace the bulbs. You might need to remove a couple clips in the fender wells as well, can't remember if that was needed to remove the shield.
Good luck
Good luck
Viorent Grip! EG
15
Jun 7, 2004 01:54 AM
