99 Accord V-6...NO SPARK...ARGHHHH
Old Jul 24, 2007 | 04:51 AM
h2omike's Avatar
Default 99 Accord V-6...NO SPARK...ARGHHHH
Checked the ignition switch, all fuses, ohmed out the coil, checked voltage at the coil and at the ignition module.....no spark coming from the main distributor wire.
Is there a main relay, or something else i can check besides replacing the Ignition module?
Old Jul 24, 2007 | 07:21 AM
Skandalous INC's Avatar
Default Re: 99 Accord V-6...NO SPARK...ARGHHHH (h2omike)
The main relay under the dash won't prevent you from getting spark.
Example:
The main relay went out on my 99 EX. Common occurrence from my understanding. It was getting spark so I could rule out ECU and ignition. But the fuel pump wouldn't kick on.
So... you could have a bad distributer. But you say you checked voltage at the coil but no spark coming from the main distributer wire... have you completely ruled out ECU, maybe ECU ground?
Old Jul 24, 2007 | 10:18 AM
h2omike's Avatar
Default Re: 99 Accord V-6...NO SPARK...ARGHHHH (Skandalous INC)
No, I haven't completely ruled out the ECU....and now I haven't completely ruled out the coil either, since I just read that the coil could ohm fine, but have an open under load...guess I shouldn't have returned the one I bought....
The problem was intermittant until recently when it became permanent...never stalled while running, just occassionally wouldn't start...sometimes after just being on...
I found a nice website on this forum that should help immensely:
http://techauto.bravehost.com/
Old Jul 24, 2007 | 05:31 PM
phootbag's Avatar
I suspect ignition coil or ignitor. Are there any DTC's in the system?
Old Jul 25, 2007 | 04:11 AM
h2omike's Avatar
Default Re: 99 Accord V-6...NO SPARK...ARGHHHH (phootbag)
Ahhhh......fortunately for me, a Google search on the acronym DTC yielded favorable results (although Direct Torque Control and Developmental Test Bed sounded interesting)
No, according to Honda Service, no DTCs. I took it to them when the problem was intermittant to diagnose...it reoccured while I was explaining the issue, but of course, after I left, the car started fine and they couldn't duplicate the problem...they did however, tell me I needed a new battery...after they repeatedly tried to duplicate the issue of the car not starting("do you want us to replace it?"...uhhhhhh)
Nothing against Honda...intermittants are tough..I'm sure if I towed it to them now that it's dead, they'd diagnose it...but no.
d-alva54
Oct 25, 2014 10:56 AM
-Hooper-
Jun 8, 2009 08:42 AM
manuelesr
35
May 21, 2008 09:31 PM
ezol
Jul 8, 2007 05:51 PM
10seceg
Jan 14, 2004 08:39 AM
