shock piston top nut wont tighten
I am only having this problem with the rear shocks. They are kyb gr2s with stock springs. The very top nut that threads down the shock piston will not go down all the way like the fronts did. I even tried using pliers to keep the piston from spinning with the nut but the nut seems stuck. Any ideas?
SD_EM1
Jul 16, 2003 04:42 AM
