best camber kit for 96 accord
Old Jul 23, 2007 | 07:35 PM
chadnixon's Avatar
Default best camber kit for 96 accord
My car (96 accord) has been lowered for quite some time now without the camber being too bad, however it is a bit harder on the tires then id like so Im going to throw a camber kit in it. My only question is what are you guys having the best luck with? Which companies, and which designs are better then the others? I've seen a few different designs for the front like adjustable lower ball joints, or new adjustable mounts for the upper control arms. Which work better, and are easier to install and adjust after?
As for the rear, pretty much all im seeing is the adjustable upper link which seems like it should do the trick.
What about this set-up?
http://cgi.ebay.com/ebaymotors...wItem
lowcd5
Apr 1, 2012 10:59 PM
dspinz9747
Apr 15, 2010 09:35 AM
jthrasher1
May 13, 2009 05:22 PM
professorman
Nov 25, 2007 01:50 PM
silveratljetta
Aug 9, 2007 07:57 PM
