Integra Idle adjusting
Old Jul 23, 2007 | 07:34 PM
NSX-TACY's Avatar
Default Integra Idle adjusting
Im trying to decrease my idle speed, its kinda high at 1000-1500rpm. Refering to this:
http://www.team-integra.net/se...D=195
, i started the car and pulled out the IAC clip the car just shutoff, instead of just decreasing 100rpm. IS the car sposed to shut off when you take out the iac clip? If its not whats wrong?
Thanks
Modified by NSX-TACY at 8:50 PM 7/23/2007
Old Jul 24, 2007 | 08:09 AM
NSX-TACY's Avatar
I also turned the idle adjust screw all the way back and still it stays around 1200 to 1500.
Old Jul 24, 2007 | 10:15 AM
VTEC_PRODUCTION's Avatar
Default Re: (NSX-TACY)
i would reccomend getting the haynes or helms manual...i have not heard of taking off a clip in order to adjust idle speed...
Old Jul 24, 2007 | 12:21 PM
NSX-TACY's Avatar
Do 1996 integras have a form of the FITV? Cause my integra goes to 1500rpm till it warms up then goes to 700rpm...
Old Jul 24, 2007 | 01:25 PM
St Jimmy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NSX-TACY &raquo;</TD></TR><TR><TD CLASS="quote">Do 1996 integras have a form of the FITV? Cause my integra goes to 1500rpm till it warms up then goes to 700rpm...
Yes they do. That was probably your problem. Were you trying to change the idle while the motor wasn't up to operating temp yet?
CaliforniaDad
Mar 15, 2012 04:59 PM
Paprika
May 8, 2007 03:18 PM
InTeGrA B18b1
Sep 13, 2002 08:31 PM
