205/50/15 on a 15x6?
Old Jul 23, 2007 | 07:10 PM
exare250's Avatar
Default 205/50/15 on a 15x6?
is anyone running a 205/50/15 on a 15x6?
too wide? any complaints? good combo? i need a new set of tires for my teg mesh's
-vandy
Old Jul 23, 2007 | 08:10 PM
exare250's Avatar
bump
Old Jul 23, 2007 | 10:32 PM
gsrious's Avatar
just about everyone with their gsr/ls/si rims runs this tire size.
so yes, you can use them.
Old Jul 23, 2007 | 10:58 PM
r.wright's Avatar
Default Re: (gsrious)
should be fine but what year and model car do u have?
Old Jul 23, 2007 | 11:39 PM
exare250's Avatar
97 hatchback w/ stock suspension.
ill be running adjustable omni's here soon so it should not be a prob right?
Old Jul 23, 2007 | 11:53 PM
r.wright's Avatar
Default Re: 205/50/15 on a 15x6? (exare250)
yep
Old Jul 24, 2007 | 06:37 AM
slammed00si's Avatar
Default Re: 205/50/15 on a 15x6? (Opossum Jenkins)
why not use the 195/50/15. i used to use the 205 but when you are low they tend to rub. the wider 205 adds almost no performance gain so i say just run the 195.
Old Jul 24, 2007 | 11:14 AM
r.wright's Avatar
Default Re: 205/50/15 on a 15x6? (slammed00si)
195/50 is the wrong size for that year....195/55 is correct but then 205/50 is slightly shorter and still good
Old Jul 24, 2007 | 01:05 PM
exare250's Avatar
jenkins you are the man. thank you!
Old Jul 24, 2007 | 06:00 PM
r.wright's Avatar
Default Re: (exare250)
you are welcome... 195/50 is almost one inch shorter and will throw yer gearing off and will look undersized for your application..happy trails
Old Jul 24, 2007 | 08:37 PM
Default Re: (Opossum Jenkins)
195 is the width it will not look shorter only thinner by 10mm. i am looking at a 195/50 and a 205/50 right outside my house and they are about the same diameter.
Old Jul 24, 2007 | 10:40 PM
exare250's Avatar
i think you are wrong, because the second number is an aspect ratio. so a 205/50 is actually a 205 wide tire and the sidewall is 50% of that 205. a 195/50 will have a shorter sidewall because 50% of 195 is less then 50% of 205.
Old Jul 24, 2007 | 11:56 PM
r.wright's Avatar
Default Re: (slammed00si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed00si &raquo;</TD></TR><TR><TD CLASS="quote">195 is the width it will not look shorter only thinner by 10mm. i am looking at a 195/50 and a 205/50 right outside my house and they are about the same diameter. </TD></TR></TABLE>
195/ is the width..which is 10 mm less wide then 205.. yes but then 50 series equals the percentage of the tire the sidewall takes up. i was referring to height not width....so assuming the OP has a honda friendly offset(35-45) then 205/50 will not be an issue for him. no need to get the wrong size tire for his year/model of vehicle.
195/55 diameter = 23.4
205/50 diameter = 23.1
195/50 diameter = 22.7
yes...u are only off by a few ticks
but 195/55 or 205/50 is the correct/recommended size for his year vehicle.
Old Jul 25, 2007 | 05:31 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Opossum Jenkins &raquo;</TD></TR><TR><TD CLASS="quote">but 195/55 or 205/50 is the correct/recommended size for his year vehicle. </TD></TR></TABLE>
Here is how these sizes compare in overall diameter to his stock size (OJ gave the diameters, here are the percentage differences):
185/65-14 (stock)
195/55-15 -0.1 percent
205/50-15 -1.7 percent
195/50-15 -3.4 percent
3.4 percent is a big difference in diameter. This is why 195/50-15 is too small for a '97 Civic hatchback.
Old Jul 25, 2007 | 10:27 AM
Default Re: (nsxtasy)
ahh i see my bad. thank you for explaining it to me so i didnt continue to look like a complete idiot.
Old Jul 25, 2007 | 11:05 AM
nsxtasy's Avatar
H-T Order of Merit
No problem, it's all good.
The 195/50-15 is the right 15" size for '95 and earlier Civics. The '97-00 Civics all are better with 195/55-15 or 205/50-15, and later Civics need even bigger sizes.
It gets even more complicated with the '96 Civic; the DX and hatchback models need 195/50-15, and the other models that year need 195/55-15 or 205/50-15.
Pretty confusing, huh?
Old Jul 25, 2007 | 11:44 AM
exare250's Avatar
honda-tech
eg.reddragon
May 17, 2013 12:22 PM
PreyStayShun
Mar 7, 2011 01:20 PM
mrdeadman
Jun 3, 2006 06:24 AM
integraboi1010
Jun 11, 2004 10:33 AM
