turn signal problems=[
Old Jul 23, 2007 | 06:29 PM
ABCVTEC's Avatar
Default turn signal problems=[
I was driving and noticed I had a fast blinker when I signal left so I took a look at my headlight turn signal. I took it out and noticed that the black wires are not connected at all. So I reconnected the black wires and still nothing happens.
My lower front left turn signal also does not work. There is a black wire coming from that as well, where should that be connected? When I connect it to my headlight turn signal it makes them light up, and also blink when I signal.
It looks like the previous owner f'd this all up. Theres are all sorts of weird rigged wires, but only the left side. My right side works fine. My fuses are all fine too. This is on a 1993 DA Integra.
Where should I connect that black wire from my lower turn signal? And, am I not getting any power in my head light turn signal when I connect the black wires because maybe the red wire and the green wire are not getting power? Ugh this is so f'd up
All of these wires are black.
Help is greatly appreciated!!!
Old Jul 23, 2007 | 06:54 PM
ABCVTEC's Avatar
Default Re: turn signal problems=[ (ABCVTEC)
Nevermind I figured it out. I'd explain the craziness of the wiring situation but I doubt anyone will ever run into it unless you have a moron do an alarm for you, like the previous owner of my car did.
Old Jul 23, 2007 | 06:58 PM
VTEC_PRODUCTION's Avatar
lol im glad i could help...
Old Jul 23, 2007 | 09:44 PM
ABCVTEC's Avatar
Default Re: turn signal problems=[ (VTEC_PRODUCTION)
Long story short: I figured out that the "two wires from engine bay" were completely dead grounds because whoever installed the alarm cut them for reasons unknown. So basically I had to resplice into those way the expletive down into the motor.
Yeah.......
Old Jul 23, 2007 | 09:52 PM
91DA9's Avatar
Yeah, I am no wiring expert, but I have seen some pretty hack jobs. Even with all the terrible body kits and what not that get thrown on Hondas it seems that the bane of most ricers is not style, but electrical wiring. They simply refuse to understand it, or even attempt to.
Syper
Dec 19, 2009 03:54 PM
vietnameeh
Jan 9, 2006 08:39 PM
That Sob
Sep 17, 2005 10:37 AM
NathanMorris
Jul 14, 2004 09:45 PM
Carlo
Oct 2, 2003 10:03 AM
