Valve adjustment question?
Old Jul 23, 2007 | 06:07 PM
Twolowpaco's Avatar
Default Valve adjustment question?
I am new to Hseries. I just adjusted all the valves according to chilton's specs. Intake .009 to .011 and exhaust .011 to .013. I adjusted them the way I have always adjusted valves, in between the adjustment screw and the valve cap. Then I read the DIY valve adjustment in the FAQ's. It shows him using the feeler gauge between the cam lobe and the rocker. And from multiple comments it looks like they all are using like intake .005 to .006 and exhaust .007 to .008. Now I'm nervous. I have a usdm 97 h22a4 with type-s cams. Some honda guru set me straight please!!
Old Jul 23, 2007 | 06:10 PM
mattsnooz's Avatar
Default Re: Valve adjustment question? (Twolowpaco)
isn't that either metric or imperial?..maybe??
what type of guages do you have?
Old Jul 23, 2007 | 06:22 PM
street_ride14's Avatar
Default Re: Valve adjustment question? (mattsnooz)
Do they make a Chilton's for a '97 lude ?? Anyways, my Chiltons for the 4th gen does NOT say "" Intake .009 to .011 and exhaust .011 to .013 "", I don't know where you got those numbers, but they are incorrect. .006-.007 IN, .007-.008 EX are the specs for the h22 series.
Old Jul 23, 2007 | 06:32 PM
Twolowpaco's Avatar
Default Re: Valve adjustment question? (street_ride14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz &raquo;</TD></TR><TR><TD CLASS="quote">isn't that either metric or imperial?..maybe??
what type of guages do you have?</TD></TR></TABLE>
I have both sets of feelers if by imperial you mean standard. And there is a big difference between both of them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 &raquo;</TD></TR><TR><TD CLASS="quote">Do they make a Chilton's for a '97 lude ?? Anyways, my Chiltons for the 4th gen does NOT say "" Intake .009 to .011 and exhaust .011 to .013 "", I don't know where you got those numbers, but they are incorrect. .006-.007 IN, .007-.008 EX are the specs for the h22 series.
They do make one for a 5thgen lude and I got the numbers from the valve clearance section from the spec sheet of the manual. If I have to I will take a pic of the page when I get home. And also I'm assuming the gauging at the cam lobe is the same. I'm not really worried about that. Just the specs.
Old Jul 23, 2007 | 07:09 PM
bluedlude's Avatar
hmmm. i know fifth gens have a sticker UNDER THE HOOD that tells you what to set the lash at.
Old Jul 23, 2007 | 07:20 PM
Twolowpaco's Avatar
Default Re: Valve adjustment question? (bluedlude)
Yeah I heard that. The lude I got my motor from Has a lot of the roof ripped off including the hood. I think Ill just feel better if someone with a 5th gen tells me what they set theirs at and the car runs good. Or if someone has their stock hood that would work too.
Old Jul 23, 2007 | 07:47 PM
bluedlude's Avatar
since no one else is going to answer,
intake : 0.15-0.19 mm (0.006-0.007 in)
exhaust : 0.17-0.21 mm (0.007-0.008 in)
good luck
Old Jul 23, 2007 | 08:30 PM
Twolowpaco's Avatar
Well i have my chiltons right here and it says what I said. Maybe a misprint? Oh well. Thank you very much for the answer.
Old Jul 23, 2007 | 08:47 PM
CGags13's Avatar
you were quoting the h23 specs man...h22s are .006-.007 intake and .007-.008 exhaust..invest in angled feeler guages and a snap on adjustment tool if you have a h22...h23's are way easier and only require a standard wrench, feeler guages, and a screwdriver
HeartOfRRR
Dec 16, 2008 01:49 PM
RanCRX
Nov 10, 2007 09:02 AM
B18ceed
Feb 22, 2006 01:10 PM
civic919900
Sep 27, 2005 08:52 AM
coupon
Dec 1, 2004 11:55 AM
