Shift linkage and radiator problems during my swap.
I got an avid shift linkage on ebay.. and everythign bolted in great.. using an LS shifter.. and i can only find like 3rd and 4th.. the shifter doesn't want to go left or right without popping back in the middle 3rd and 4th gears. also radiator has a leak and its hard to find.. any tips? thanks guys -Matt-
Take the radiator to a shop and have it pressure tested........and as far as your linkage...........
......whats the vehicle and what is the swap......
90 CRX DX. b18a1. I havent even checked if there's manual trans fluid in it, but would that cause it to not go in a gear?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by birdricer »</TD></TR><TR><TD CLASS="quote">90 CRX DX. b18a1. I havent even checked if there's manual trans fluid in it, but would that cause it to not go in a gear?</TD></TR></TABLE>
it COULD, but i doubt thats your problem.....
This may sound dumb but i had a similar issue with my avid shift linkage. Flip the linkage over. My issue was it was shifting waaaay to far forward. (4th gear was were nutral was)
Anti-Drama Queens
Apr 8, 2006 05:27 PM
chad174
Sep 1, 2003 12:12 AM
type Gendy
22
Aug 18, 2003 03:42 PM
