Front end noise
Old Jul 23, 2007 | 01:17 PM
ch0g0nda's Avatar
Default Front end noise
Hey all.
I'm getting a nice clunking noise from the front end of my car when I break firmly or go over bumps.
I know next to nothing about suspension so I thought I'd ask.
Thanks for any help.
Old Jul 23, 2007 | 01:18 PM
cschaible's Avatar
B A N N E D
Default Re: Front end noise (ch0g0nda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ch0g0nda &raquo;</TD></TR><TR><TD CLASS="quote">Hey all.
Thanks for any help.</TD></TR></TABLE>
It would really help if you posted some information about the car.....and first and foremost, use the Search Function!!!!
Old Jul 23, 2007 | 01:25 PM
ch0g0nda's Avatar
Default Re: Front end noise (cschaible)
Alright, it's an EF. It has a B18. It's got some garbage Tokico blue dampers on cheap'o ebay coilovers that the po left me with. The car has 360,000km (ish) and as far as I know nothing but the springs/dampers have been changed.
I'm finding the search function fairly useless I'm wanting to find out about putting a twin-turbo H22 swap into my '88 STD hatch with rust.
Old Jul 23, 2007 | 03:06 PM
VtecSyndrome's Avatar
Could be axles but that's not for sure, have to let somebody hear it or feel it to know for sure. Axles can start popping like like under hard braking and or accelerating even before you ever hear popping around turns like a typical axle problem indicates. If you don't know that much about your car don't try to just throw parts at it to fix it, pay the $40.00 to have a Honda tech check it out so you can spend the money in the right spot the first time
Old Jul 23, 2007 | 06:23 PM
ch0g0nda's Avatar
Default Re: Front end noise (VtecSyndrome)
Kinda weird that you mention popping. I was just out in the car and noticed it popping away from stops and a little under breaking.
That isn't what I was asking about originally. It's this low clunking noise I get when I break. It's like there's slack somewhere in the front end and it's casing something to slam together a bit. Tie rod's?
Old Jul 23, 2007 | 06:29 PM
like I said axles can cause this exact problem. but you gotta check it out and see if there are anu other loose parts in the suspension, not likely its the tie-rods but I can't tell you w/o seeing it myself.
jdm_h22
Nov 16, 2008 04:09 PM
dumkopf
Oct 28, 2007 08:32 AM
pearl
Aug 31, 2007 03:47 PM
Crosser
26
Jan 16, 2002 06:35 PM
