Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
no vtec oil pressure switch
Old Jul 23, 2007 | 01:07 PM
teamworxek9's Avatar
Default no vtec oil pressure switch
im doing a swap for this kid i know he was told its a jdm gsr engine. it has no vtec oil pressure switch or a hole for one. what ecu would run vtec without this switch? anyone have any info on this head? i know im going to end up tapping the block but im just curious.
Old Jul 23, 2007 | 03:03 PM
MatterMatt's Avatar
Default Re: no vtec oil pressure switch (teamworxek9)
JDM engines don't have a VTEC pressure switch on the solenoids. Only a JDM ecu will run the motor with VTEC working and no code for a VTEC pressure switch. You don't tap the block for anything, just run the JDM GSR ECU.
Old Jul 23, 2007 | 04:49 PM
so your saying only jdm gsr engines dont have this? were is the swith located or does it not use one.
Old Jul 23, 2007 | 05:14 PM
MatterMatt's Avatar
Default Re: (teamworxek9)
All JDM B-series engines do not have a VTEC Pressure Switch (my JDM ITR doesn't have one either). I won't say all JDM engines don't have them because I'm not 100% sure the D, F and H series don't also. They don't use a Vtec Pressure Switch, just a spool valve. If you run the JDM ECU you will be fine.
Old Jul 29, 2007 | 04:05 PM
my b16 has one and its a jdm engine obd0
Old Jul 29, 2007 | 04:27 PM
toyomatt84's Avatar
Sanji
What car is this for?
KPowerSquadron
Aug 29, 2010 05:17 PM
oneoffaccord
Aug 21, 2006 10:59 PM
94BlackRS
Jun 30, 2003 06:43 AM
