What do you use to cut pipe?
Old Jul 23, 2007 | 12:32 PM
Underwhere's Avatar
Default What do you use to cut pipe?
I've been cutting all my SS and alum pipe with a chop saw with an abraisive wheel.
It sucks.
I've been looking for alternatives to get a cleaner, more accurate cut.
I was looking at band saws today but I don't think the geometry of most band saws is very versatile.
I'm looking for what you guys use.
Also, what filler metals are you guys using for 304 to 304? My welds look like butt when I use 308L.
Modified by Underwhere at 6:22 PM 7/23/2007
Old Jul 23, 2007 | 01:43 PM
RCautoworks's Avatar
Default Re: What do you use to cut pipe? (Underwhere)
Bandsaw, have a chop saw but that rarely gets used.
Old Jul 23, 2007 | 02:43 PM
EdsGTI's Avatar
Default Re: What do you use to cut pipe? (RCautoworks)
i use a wilton bandsaw, i have a chop saw that i use when the bandsaw blade wears out.
Old Jul 23, 2007 | 02:54 PM
ebydrc's Avatar
Banned
cut off saw for SS and band saw for alu and sch10 (for accurate cuts)
Old Jul 23, 2007 | 03:37 PM
2kjettaguy's Avatar
Default Re: (ebydrc)
cold saw
Old Jul 23, 2007 | 04:08 PM
ROTARY's Avatar
i use the bandsaw for fine cuts, chop saw for cuts that don't need to be perfect.
if you get a bandsaw i recommend you buy aggressor brand blades, they cut fast, stay sharp and they last.
what thickness is the disk you are using?
Old Jul 23, 2007 | 05:07 PM
Howitt's Avatar
Default Re: (ROTARY)
if you want a **** way to do it and have it perfect. CNC mill with a rotary 4th axis.
Old Jul 23, 2007 | 05:24 PM
Underwhere's Avatar
Default Re: (Howitt)
You guys using vertical band saws or horizontal band saws?
Old Jul 23, 2007 | 05:27 PM
Default Re: (Underwhere)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Underwhere &raquo;</TD></TR><TR><TD CLASS="quote">You guys using vertical band saws or horizontal band saws?</TD></TR></TABLE>
Both, 7 inch horizontal bandsaw, 4x6 vertical bandsaw.
The 7 inch is a monster compared to the 4x6, it will rip anything right out from the vice if its not in there good enough. And the blade never pops off, if anything its the piece that will come out of the vice.
Old Jul 24, 2007 | 05:57 AM
Howitt's Avatar
Default Re: (RCautoworks)
I use my 15" x 20" horizontal band saw to cut my pipe
Old Jul 24, 2007 | 06:30 AM
KFMRC's Avatar
The best and most versatile saw for doing tube and plate when you need to buy just one is the vertical band saw. It is the most used saw in the shop by far. It is also the saw that will adapt the best to fixtures for cutting collectors and things or even fixtures for cutting tubing for headers. You need to buy a good saw that is meant for cutting steel not a wood saw converted. I use a doall. These saws will last and many in use today are from the second world war. They are indestructable
and parts though expensive are available. When you think about how old some of these are parts that seem expensive really aren't.
16" saw is a good size for most anything. Most doall's will be 3 phase so a phase converter might be needed. Nothing to be afraid of though and once you have one you will find allot more equipment.
I have also found that specialty saw in conn is the best source for blades maybe not always the cheapest but great quality and service -800-225-0772
Old Jul 24, 2007 | 04:42 PM
hucoreyCRX's Avatar
I use a 6" Metabo hand grinder with .045" cutoff wheels and I use a tiger wheel to buff the burs off. For a hand grinder they are pricey. About $250. I like it better than a band saw because it is easier to follow your cut marks on your material. They are the best in the industry and you will not find any other hand grinder in a true welding/fabrication shop.
Old Jul 24, 2007 | 06:29 PM
Howitt's Avatar
Default Re: What do you use to cut pipe? (hucoreyCRX)
I second the metabo grinders. I have two of them, the cord will fall off before the grinder goes bad. Ive bought mine used and they are still top notch
Old Jul 24, 2007 | 07:17 PM
CRMB's Avatar
OG Fabricator
Default Re: What do you use to cut pipe? (Howitt)
Our fabricators prefer cold saws. They have access to most everything here but laser, and the manual cold saws are nearly always backed up. It would be a good idea to get a variable speed control if you do, it will allow you to tweek the blade speed to material & size.
Old Jul 25, 2007 | 12:45 PM
robx7fcna's Avatar
Default Re: What do you use to cut pipe? (Racing-Solutions)
This is what I have
it doubles as a cut off saw and a band saw. when you have it in the upright position, it can be locked in place and ther is a table that bolts on.
as for blades I use anything bimetal, HSS blades wear out really quick but the price of them reflects that.
Old Jul 25, 2007 | 02:45 PM
MAFDARK's Avatar
nevermind i cant read
Modified by MAFDARK at 7:15 PM 7/25/2007
Walterronny
Welding / Fabrication
84
Feb 16, 2014 04:35 PM
Walterronny
Nov 18, 2013 01:43 PM
Walterronny
Apr 16, 2013 02:37 PM
96supercharged
36
Jan 23, 2008 02:17 PM
D-Man
Nov 6, 2002 01:35 PM
