Four Corners, no lights. :(
Old Jul 23, 2007 | 12:29 PM
IamPhil's Avatar
Default Four Corners, no lights. :(
I didn't notice this when buying my Integra so while owning it I never realized that all other Integras have lights on the corners, I used to think they were just reflectors. Well the other day I checked my lights, and all four corners next to the signal lights, are all out. I don't get it, do I have four bad bulbs or a blown fuse??
Old Jul 23, 2007 | 01:03 PM
IamPhil's Avatar
Default Re: Four Corners, no lights. :( (IamPhil)
I don't think it's a blown fuse, because I don't see a fuse listed for "corner lights" nor do I think it's all four bulbs because I checked the front two bulbs and they look fine, I'll admit I couldn't figure out how to get out the rear two. Is there a chance that these are listed as day time running lights? because I don't have fuses in those slots, but neither do any of my friends, it's listed as a Canada only feature.
Old Jul 23, 2007 | 01:51 PM
zsudz922's Avatar
the day time running lights are only on the Canadian versions.i would at least just go and buy one new bulb(or 4 and if they dont work you can just return them).clean the metal prongs where the bulb goes(also make sure they make contact with the bulb some times they get smashed down),check the wires and make sure they are in good condition(are not frayed or anything),make sure the grounds are good and tightened down.hopefully that will work.
Old Jul 24, 2007 | 02:03 AM
IamPhil's Avatar
Default Re: Four Corners, no lights. :( (zsudz922)
I got new bulbs, but they still won't light, the wires look fine so I was hoping it was a fuse. But I don't see a fuse for these lights.
Old Jul 25, 2007 | 10:00 AM
IamPhil's Avatar
help?
Old Jul 25, 2007 | 12:07 PM
dizzzane's Avatar
what happens when you attempt to use a turn signal... no blink, blink fast, normal.... could be a fuse that controls all lights but only is says headlights or tail lights... i dunno sounds strange
Old Jul 25, 2007 | 02:33 PM
IamPhil's Avatar
Default Re: Four Corners, no lights. :( (JDM_dc2_B18c)
In my car only half the front corners are lighted and blink when signaling but in other integras the entire corners are lighted and half of the corners blink when signaling. I thought this was all normal until I saw my friend's Integra behind me.
And incase that didn't come out too clear, I meant half of each corner just incase some people thought I meant one out of the two corners.
Old Jul 25, 2007 | 04:15 PM
ThA IntegrA HI's Avatar
are you sure that its not different with the parking lights on? i know the fronts blink differently when those are on.
Old Jul 25, 2007 | 09:09 PM
IamPhil's Avatar
Default Re: (ThA IntegrA HI)
Yeah, the lights to the outside of the car haven't come on before. And since they don't come on at all I've always assumed they were reflectors till I saw other people's tegs.
Johnoolo
Jan 14, 2014 12:24 PM
chirby17
28
Apr 19, 2012 09:14 AM
mitzi
Honda Civic (2001 - 2005)
Jul 30, 2011 10:30 PM
sam0218
Nov 19, 2006 04:32 PM
teggsr925
Apr 25, 2006 04:02 AM
