launch control
Old Jul 23, 2007 | 10:49 AM
fin781's Avatar
Default launch control
My vehicle speed sensor went out, so my speedo stays on zero. I was wondering if that would effect the launch control?
Old Jul 23, 2007 | 12:10 PM
TrueNorthStar's Avatar
Default Re: launch control (fin781)
What are you using to control your launch? ECU? MSD?
Need more information.
Old Jul 23, 2007 | 01:26 PM
fin781's Avatar
Default Re: launch control (TrueNorthStar)
my bad, its my ecu, a friend is chipping it.
Old Jul 23, 2007 | 01:30 PM
mengy007's Avatar
I have a chip with launch control that sets a rev limit at 0mph. If yours is like this then it will probably affect your launch control because it will always read your mph as 0mph.
Old Jul 23, 2007 | 08:46 PM
Default Re: launch control (mengy007)
You can setup the ecu to control the launch control to work off of a clutch switch, but if yor are using a speed threshold to trigger the launch control then, yes a broken vss will not allow the lauch control to work properly.
s10cky
Dec 5, 2006 05:08 PM
CLE
Sep 11, 2006 10:06 AM
