Need Help on civic cx hatch
ok my car is burning oil and i have to put 1qt of oil every three days and i wonder is it my piston ring are goin out or is my head gasket or is my oil pan gasket
Are all your fluid mixing together?? like is there water in the oil? or oil in your radiator fluid? that would mean your headgasket would be bad. and are u linking oil from your oil pan gasket? u would have to get under the car and look for that. let me know
if the smoke is white, check for a bad head gasket...if it is bluish dark, piston rings.
if oil pan shows a bunch of oil on it, clean it and check in a couple of days, you will see the leak.
pinoyboy204
Sep 2, 2005 05:32 AM
