dime size holes
Old Jul 23, 2007 | 03:59 AM
swtch7's Avatar
Default dime size holes
What would be the best way/and other options to patching dime size holes. The ones in particular that im talking about are the door trim holes once the trim is removed. The car is already down to primer.
Thanks for all the help!
Old Jul 23, 2007 | 05:35 AM
WihaSi's Avatar
Default Re: dime size holes (swtch7)
Welding them shut would be the correct method, others will tell you to fill them with fiberglass.
Old Jul 23, 2007 | 06:27 AM
swtch7's Avatar
Default Re: dime size holes (WihaSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WihaSi &raquo;</TD></TR><TR><TD CLASS="quote">Welding them shut would be the correct method, others will tell you to fill them with fiberglass.</TD></TR></TABLE>
If I did go the fiberglass route, what would be the disadvantages? Would I have to worry about it cracking or anything? And with the doors being so thin, if I welded, would that warp the door panel at all?
thanks for your response
Old Jul 23, 2007 | 06:55 AM
dinko's Avatar
you tack weld while alternating sides you place the tack welds...then grind down, apply filler, sand, smooth, primer/sealer, paint, clear
Old Jul 23, 2007 | 07:38 AM
WihaSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swtch7 &raquo;</TD></TR><TR><TD CLASS="quote">
thanks for your response </TD></TR></TABLE>
You would definately have to be careful when welding, you would have to tack weld it to insure that you didn't heat the panel too much. If you tried to plug weld it, you would most likely warp the panel.
I've never filled holes using the fiberglass method, so maybe someone else can chime in and inform you a bit more on that.
Old Jul 23, 2007 | 07:53 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Keep in mind these holes are on/in your door, which likely gets closed/slammed quite often. I wouldn't use any method, but welding.
Old Jul 23, 2007 | 08:54 AM
swtch7's Avatar
Default Re: dime size holes (-NA-aLL-thE-wAy-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -NA-aLL-thE-wAy- &raquo;</TD></TR><TR><TD CLASS="quote">Keep in mind these holes are on/in your door, which likely gets closed/slammed quite often. I wouldn't use any method, but welding.</TD></TR></TABLE>
This is a very good point. Guess its time to learn how to weld , thanks
projectSI4o8
Audio / Security / Video
Feb 12, 2011 02:05 PM
wrathofthesun
Mar 5, 2009 09:12 AM
}-Black-Ls-Stunna-{
Oct 26, 2008 12:11 PM
JSiRTO
May 9, 2007 08:04 AM
