Ohlins Suspension - Does anyone here use them? I need your impression!!
Old Jun 10, 2002 | 06:19 AM
Christian's Avatar
Default Ohlins Suspension - Does anyone here use them? I need your impression!!
I would like to know if anyone is running this Ohlins setup? This setup has 5 way hieght adjustment. I will be doing a combination of normal street driving, Road Racing and Auto-X. I know Ohlins is an excellent strut, I really want to get people's driving impression of them.
[Modified by Christian, 11:00 AM 6/10/2002]
Old Jun 10, 2002 | 06:22 AM
len's Avatar
len
Default Re: Ohlins Suspension - Does anyone here use them? I need your impression!! (Christian)
They look like alot of $$$$$$$.
Going by the name, I bet they are high quality stuff with custom spring rates and adjustable dampers. I've only seen them in my Hyper Rev.
Old Jun 10, 2002 | 10:15 AM
Christian's Avatar
Default Re: Ohlins Suspension - Does anyone here use them? I need your impression!! (iloveracing)
Yes, they are a little expensive. But all the good stuff usually is
[Modified by Christian, 5:18 PM 6/10/2002]
Old Jun 10, 2002 | 01:30 PM
Christian's Avatar
anyone use OHLINS???
Old Jun 10, 2002 | 02:35 PM
Type Goch's Avatar
New User
Oh yea and ESPECIALLY the Eibach ERS/Koni setup...
[Modified by Type Goch, 3:44 PM 6/10/2002]
Old Jun 10, 2002 | 03:32 PM
EagleR's Avatar
Default Re: Ohlins Suspension - Does anyone here use them? I need your impression!! (Type Goch)
Never used them....but I know they make most of the TRIPLE ADJ...for CART etc...and Penske Triples as well so they can't be bad.
Old Jun 10, 2002 | 04:02 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Ohlins Suspension - Does anyone here use them? I need your impression!! (EagleR)
I bet they're nice. I'm thinking about Ohlins shocks/struts for the Turbo Pig. Remote reservoir, eight-position adjustable:
$1700 for the front and back
Pat, who wonders if Ohlin fronts/Koni Sport backs would be driveable
[Modified by itr009, 8:02 PM 6/10/2002]
Old Jun 10, 2002 | 04:58 PM
Flux's Avatar
Default Re: Ohlins Suspension - Does anyone here use them? I need your impression!! (itr009)
Very nice. Can someone explain the benefits of the remote reservoir to me....
Old Jun 10, 2002 | 05:03 PM
JDM_DOHC_SiR's Avatar
New User
ITRinEJ has a major back set on His Civic Coupe.... Hit him up ..I know that he found ause set that was cherry when he was out here in Japan in April
Old Jun 10, 2002 | 05:59 PM
_BEN_'s Avatar
I have a set on my eg6SiR they ride fairly stiff for the street but the feel great on the freeway when you get above 120kmh.
i am running them with ohlins springs and cusco upper pillow mounts. i dunno the spring rates because i bought the whole set up used and the the guy at showa didnt know.
the only bitches i have is that the pillows make a little noise and the stiff ride gets annoying cuz japans roads are all screwed up.
Old Jun 10, 2002 | 06:01 PM
Gansan's Avatar
Default Re: Ohlins Suspension - Does anyone here use them? I need your impression!! (Flux)
I believe the most common reason is to increase the volume of oil in the damper. This allows it to handle more heat without getting too hot and changing viscosity. As a damper heats up from use, the oil gets thinner, and the damper fades.
In the case of the Ohlins, there is separate valving inside the reservoir that provides additional damping action in series with the main damper. By adjusting the reservoir damping, you have more flexible control over the shape of the damping curve than you have with normal multi-adjustable dampers.
Old Jun 10, 2002 | 06:03 PM
Splat's Avatar
Default Re: Ohlins Suspension - Does anyone here use them? I need your impression!! (zyg)
Come on big boy, that's less than a set of Buddy Clubs fro an R.
Did you miss the fact that it was $1700 for shocks only??
Still looking at another $300 or so for springs, because no one makes coilovers for the Pig (at least in this country)
It would be cool though... For the bling factor if nothing else
Pat, who wonders if Ed ordered his stickers from that thread in the FI forum yet
Old Jun 10, 2002 | 06:53 PM
mugenracer's Avatar
a friend of mine has them in his JDM integra SiR with ITR rear control arms, of all the cars i've been in with aftermarket suspension, his has to be the sweetest, i think they have 30 adjustments for damping and he has his set at 10 clicks from hardest in the front and 15 in the rear, IMO it is the most comfortable set up i know, firm but not too harsh and with just the right amount of bounce and rebound for fantastic handling..
Old Jun 10, 2002 | 07:03 PM
DC2#428's Avatar
very nice suspension! one of the best out there!
Old Jun 10, 2002 | 07:19 PM
done's Avatar
Default Re: Ohlins Suspension - Does anyone here use them? I need your impression!! (DC2#428)
those look good good
Old Jun 11, 2002 | 09:07 AM
Christian's Avatar
Old Jun 11, 2002 | 09:13 AM
98TypeR's Avatar
can i be correct in saying that spoons struts are ohlins? as well as mugens?
Old Jun 11, 2002 | 09:14 AM
Warren's Avatar
Wrong-Way Wang
Default Re: Ohlins Suspension - Does anyone here use them? I need your impression!! (98TypeR)
Mugen uses Showa. Dunno about Spoon.
Warren
Old Jun 11, 2002 | 09:32 AM
ITR764's Avatar
Default Re: Ohlins Suspension - Does anyone here use them? I need your impression!! (Warren)
Warren
spoon is showa as well.
Old Jun 11, 2002 | 09:52 AM
norice's Avatar
I though Ohlins shocks were $1000-$2000 per corner? $1700 for set of four does not seem all that bad. Who sells these?
[Modified by norice, 10:53 AM 6/11/2002]
Old Jun 11, 2002 | 12:44 PM
EauRouge's Avatar
Default Re: Ohlins Suspension - Does anyone here use them? I need your impression!! (norice)
The pro race Ohlins are $1000 per corner such as the ones used in Taz Harvey's car. But these Ohlins are the "cheap" ones (licensed the name Ohlins) which are made in Japan.
RedRevolver
Suspension & Brakes
21
Jul 29, 2008 07:16 PM
firefighter81
Feb 9, 2006 12:00 PM
NirVTEC
Dec 10, 2003 03:31 PM
Christian
Jun 10, 2002 07:02 AM
b18bturbo
May 13, 2002 10:52 AM
